89 prelude not starting...help
Old Jan 12, 2007 | 10:25 AM
rewerbcrx's Avatar
Default 89 prelude not starting...help
okay its the 89 si prelude, what its doing is not clicking not doing anythign when i turn the key except turn the accesories on ( ie: fan radio wipers) when i jump the starter the car starts... i can also pop start it... so the question is what could it be... when turnign the key all the way to starting position there is nothing
PLEASE some advise..
could it be the ignition swith in the column or what else? and if so what do you think it costs for something like that?
Old Jan 12, 2007 | 10:42 AM
Hawkze_2.3's Avatar
Default Re: 89 prelude not starting...help (rewerbcrx)
So it starts when you jump it?
That's your battery man...
Old Jan 12, 2007 | 11:27 AM
Lewdin' Incognito's Avatar
Default Re: 89 prelude not starting...help (Hawkze_2.3)
It says when he jumps the starter, not the battery.
I have no experience before '92 Preludes, but sounds like a bad starter/starter solenoid, no?
Old Jan 12, 2007 | 11:29 AM
Hawkze_2.3's Avatar
Default Re: 89 prelude not starting...help (Lewdin' Incognito)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lewdin’ Incognito &raquo;</TD></TR><TR><TD CLASS="quote">It says when he jumps the starter, not the battery.
I have no experience before '92 Preludes, but sounds like a bad starter/starter solenoid, no?</TD></TR></TABLE>
What is jumping the starter? The starter positive wire is directly connected to the battery...
Old Jan 12, 2007 | 11:41 AM
Yeah, but there's still a mechnical switch in there (I assume) that has to close for it to see power. Just a thought.
EDIT: Lol, I guess it would be better if OP tells us whether he meant he is jumping at the battery or not. I'm probably reading into it too much.
Old Jan 13, 2007 | 10:02 AM
rewerbcrx's Avatar
what i meant was directly starting the starter through the battery without switch... i figured it out though...
it was the ignition in the column the portion that when you turn the key to start the engine is broke.. so i installed a push button swtich lol (RED NECK BABY!)
Old Jan 13, 2007 | 12:12 PM
BlueLude84's Avatar
Same thing happened to me. Turned out my alternator was going out.
caliskier
Nov 28, 2012 05:18 PM
pgpunkguy
Jan 22, 2008 11:29 AM
Touge Tuning
May 3, 2006 11:14 AM
5lugSlug
Jul 13, 2005 06:41 AM
mingchi69
Jul 14, 2003 06:14 PM
