gB18C1 mild buid, cams and timing settings advice needed.
I just put together my gsr head, bc3 cams, skunk2 pro series cam gears, supertech valvesprings, crower cromoly rets. milled head .01". I/H/E and skunk2 manifold. I already advanced timing 1 degree at the distributor, should i advance it 2 degrees? Also, should i set the cam gears? Thanks
Modified by all-mtr-teg at 11:39 PM 1/11/2007
darrinbrewer
May 12, 2006 05:46 PM
Well, since your head is closer to the block you can put both cams at +.5-1deg and start from there.
