quick swap Q
Old Jan 11, 2007 | 08:25 PM
EGhatch33's Avatar
Default quick swap Q
if i was gonna put a d16z6 into an ek would i need to switch the ek to obd1? or do i change obd at all
Old Jan 11, 2007 | 08:28 PM
gezzuzz's Avatar
Default Re: quick swap Q (EGhatch33)
in simple terms
you put your obd-2 harness on the d16z6..
(some modification need)
then you can use a obd-2 ecu or obd-1 harness with a obd-2 to obd-1 jumper harness
even if you want to go obd-1 you need to wire it as obd-2 then convert to obd-1 at the ecu
Old Jan 11, 2007 | 08:30 PM
Syndacate's Avatar
Default Re: quick swap Q (gezzuzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGhatch33 &raquo;</TD></TR><TR><TD CLASS="quote">if i was gonna put a d16z6 into an ek would i need to switch the ek to obd1? or do i change obd at all</TD></TR></TABLE>
You can use the existing OBD-II harness, you'll need an OBD-IIa to OBD-I conversion harness for the P28 ECU to plug in and you'll have to use an OBD-II distributor as well as OBD-II injectors.
Old Jan 11, 2007 | 08:33 PM
gezzuzz's Avatar
Default Re: quick swap Q (Syndacate)
you keep you injector obd-2 injectors.. you use the obd-1 dizzy just have to wire it to obd-2..
the obd-2 dizzy will not bolt up to the z6 head
Old Jan 11, 2007 | 08:36 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz &raquo;</TD></TR><TR><TD CLASS="quote">you keep you injector obd-2 injectors.. you use the obd-1 dizzy just have to wire it to obd-2..
the obd-2 dizzy will not bolt up to the z6 head</TD></TR></TABLE>
Oh, blah, I forgot about that .
I'm pretty sure you can mod the dizzy to fit, pretty sure I've heard of people doing it. Though it's easier (and cheaper) just to re-wire the plug.
I have no idea how to re-wire the dizzy/plug part .
Old Jan 11, 2007 | 08:38 PM
gezzuzz's Avatar
there is guides for this stuff.. i did it 3 times its year and still look at the guide..
Old Jan 11, 2007 | 08:44 PM
EGhatch33's Avatar
wanna show me a link to the guide? i might be swapping my z6 into an ek for someone
Old Jan 11, 2007 | 08:56 PM
gezzuzz's Avatar
http://technet.ff-squad.com/
lot of good info there..
what kind of car is it? dx cx ex?
Old Jan 12, 2007 | 09:54 AM
EGhatch33's Avatar
Default Re: (gezzuzz)
i dont know what model the ek is... i'm trying to sell my z6 w/ tranny and everything and i found someone who wants it for their ek
kaoticstyles
Jun 20, 2008 03:30 PM
NOman0608
Jul 26, 2007 10:28 AM
97DGreenEx
Oct 13, 2006 06:21 PM
Steve-
10
May 1, 2006 08:13 PM
