Sway bar endlinks ?
Old Jan 11, 2007 | 05:18 PM
kornerk12's Avatar
Default Sway bar endlinks ?
I remember a writeup on how someone had trouble with the stock endlinks in the rear with the progress sway bar so they ended up making some custom ones themselves. Anyway i found these none are made for the lude obviously but maybe they will fit idk.
http://www.inlinefour.com/blraen.html
Old Jan 11, 2007 | 09:59 PM
E-Money's Avatar
Default Re: Sway bar endlinks ? (kornerk12)
progress makes endlinks to go with their sway bar
Old Jan 12, 2007 | 01:36 PM
kornerk12's Avatar
Default Re: Sway bar endlinks ? (E-Money)
then wut was that writeup about where he made custom links ????
Old Jan 12, 2007 | 01:44 PM
CAN97SH's Avatar
Resident Hoser #1
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-Money &raquo;</TD></TR><TR><TD CLASS="quote">progress makes endlinks to go with their sway bar</TD></TR></TABLE>
Do they even sell/make the swaybars and endlinks for the Prelude? They don't advertise that on their site.
Old Jan 12, 2007 | 01:46 PM
E-Money's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CAN97SH &raquo;</TD></TR><TR><TD CLASS="quote">
Do they even sell/make the swaybars and endlinks for the Prelude? They don't advertise that on their site.</TD></TR></TABLE>
search progress's website and could find their endlinks.. even the site i got mine from summitracing does not even carry progress products anymore...but hawke's custom endlinks are the same thing that progress offed
Old Jan 13, 2007 | 04:28 AM
SnlpeR's Avatar
^^^ if you search...
youll find out the progress endinks are junk
mine lasted a drive then had play
not worth getting
Old Jan 13, 2007 | 09:18 AM
E-Money's Avatar
Default Re: (SnlpeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnlpeR &raquo;</TD></TR><TR><TD CLASS="quote">^^^ if you search...
not worth getting</TD></TR></TABLE>
play? the only downside i have with them is the noise they make.
Old Jan 13, 2007 | 01:57 PM
PrettyLude's Avatar
progress over charges you for junk man.
Old Jan 13, 2007 | 07:37 PM
bankston5thgen's Avatar
Default Re: (PrettyLude)
im so glad i saw this post. i bought the progress swaybar...it was bigger than i thought itd be. anyways the stock endlinks both broke the second day after i put the swaybar on. so i took the bar off completely for a month or two till had the money to make some endlinks myself. i heard the progress endlink kit isnt all that great and people have still had problems with it. I bought a threaded rod online somewhere (it was some insanely strong steel alloy somthin) then i bought the aurora AW7T spherical heim joints (very expensive) and put those together with the threaded rod, and some grade 8 hardware...havent had a single problem with anything swaybar related since then. and for the record, i spent a weekend at TWS w/o any problems. if anyone wants more info on this just PM me.
Old Jan 14, 2007 | 12:09 PM
E-Money's Avatar
Default Re: (bankston5thgen)
i dont see the problem here... the design of the spherical endlinks isnt that great but you have to custom endlinks to run the progress sway bar.....
Old Jan 14, 2007 | 07:26 PM
jdmnash's Avatar
Default Re: (E-Money)
DIY adjustable endlinks with baker precision-aurora rod ends ftw!!!! I am in the process of making these based on the parts listed here: https://honda-tech.com/zerothread?id=1474587
a guy on here has had these for over a year with no play. ballin
Old Jan 15, 2007 | 04:04 AM
SnlpeR's Avatar
developing play with my "XMF7 7/16 XM SERIES ROD END HEIM JOINT "
supposed to handle over 10,000 lbs
i dunno what gives
whats the AW7T rated at?
these are my 2nd set of endlinks for my progress bar
its a never ending battle with endlinks developing play for me
ugh damnit
Old Jan 15, 2007 | 05:28 AM
117's Avatar
117
Are the rod ends you're using teflon lined? If not, that's part of the problem. The weight rating has nothing to do with it, IMO.
Also, you're using 7/16" rod ends. The holes in the chassis and sway bars (on a 5Gen) are just a bit over 12mm. There's probably a 0.040" size difference between the two, which is right at 1mm. That's a big difference between the bolt and the hole! If you're using a 4Gen, the top bolt is 10mm, which gives you a 0.043" difference in size between the bolt and rod end bore.
What I did was machine some adapters that go into the upright and into the sway bar that fit tightly with a bore that's exactly 3/8". That way, the bushing fits tightly in the upright and sway bar, and the bolt for the rod end fits tightly in the bushing. I have tried two different sets of Aurora rod ends (both teflon lined), and I haven't had any problems. My current rod ends have been on the car for two seasons with no play.
I'm doing a buy on PO.com for these end links that I'm making. I probably have enough for 4 extras or so. They're quite expensive, though.
Old Jan 15, 2007 | 12:15 PM
SnlpeR's Avatar
the ones i have are supposedly teflon lined
but i only see it on the sides of the eye
the rod ends fit snug on the hardware
i used a combo of a metal sleeve that fits snug into the eye of the rod end...and some *cough* plastic tape wound tightly on the bolt
Old Jan 15, 2007 | 03:37 PM
117's Avatar
117
What brand is that? I can't find anything by searching under that PN.
Old Jan 15, 2007 | 03:43 PM
Hawkze_2.3's Avatar
Default Re: (117)
AW7T = Aurora, the 'T' indicates Teflon.
---&gt;http://bakerprecision.com/auror6.htm
and
---&gt;https://honda-tech.com/zerothread?id=1474587
Old Jan 15, 2007 | 03:59 PM
117's Avatar
117
Yes, I realize the AW7T is Aurora and teflon lined. I usually use Aurora parts or NMB. I was referring to XMF7 7/16 XM SERIES ROD END HEIM JOINT. I've never seen that PN before.
Old Jan 15, 2007 | 04:09 PM
Hawkze_2.3's Avatar
Default Re: (117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, I realize the AW7T is Aurora and teflon lined. I usually use Aurora parts or NMB. I was referring to XMF7 7/16 XM SERIES ROD END HEIM JOINT. I've never seen that PN before.</TD></TR></TABLE>
Sorry, thought you meant the other one...
needtoknow
Suspension & Brakes
Nov 27, 2007 06:18 PM
igo4bmx
Suspension & Brakes
Mar 19, 2006 10:15 AM
BB4
Oct 3, 2005 06:31 PM
DarkBB4
Jan 14, 2005 03:56 PM
unknown2
Sep 2, 2004 06:29 PM
