drill holes for aftermarket Injectors?
my aebs manifold wont let my rc injectors fit in there pre drilled hole do i need to Drill the holes out to allow them to pass through? has anyone else experienced this? i dont want to ruin anything
please help i neeed it bad and quick thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allnaturalb16 »</TD></TR><TR><TD CLASS="quote">my aebs manifold wont let my rc injectors fit in there pre drilled hole do i need to Drill the holes out to allow them to pass through? has anyone else experienced this? i dont want to ruin anything
please help i neeed it bad and quick thanks</TD></TR></TABLE>
that doesn't sound right. i thought honda rc's were oem size replacements. if oem injectors won't fit either, thats an aebs mistake.
yea i notice the same problem with my rc injectors when i put it in my aebs intake.
the rc 310 tips are bigger then stock thats the problem.
i was short on time and a tool to solve the problem so i left it. but you dont have to shave much to make them fit its only off by alittle.
the stock gsr intake manifold has a larger bore thats why it was never a problem.
i used my o rings off my sohc motor.
the gsr has the smaller o rings with the plastic spacer on the bottom and i didnt feel like making them bigger with a dremel.
its a really tight fit with the oem o rings. or you can go buy some from rc.
DualCamEJ
Apr 9, 2010 05:03 AM
