Brakes
Old Jan 11, 2007 | 12:18 PM
J9D6M's Avatar
Default Brakes
Having some trouble getting the piston pushed back farther into the caliper to put on new brake pads. I put a clamp on it and still couldnt get it back. Could it be they are shot?
Old Jan 11, 2007 | 12:26 PM
EL Vap133's Avatar
Default Re: Brakes (J9D6M)
Front or Rear brakes?
Old Jan 11, 2007 | 12:29 PM
J9D6M's Avatar
Default Re: Brakes (EL Vap133)
my mistake for not clarifying, the rear brakes on my 91 crx si...
Old Jan 11, 2007 | 12:43 PM
em2ssm02's Avatar
it might be that the pads just arent lining up or are sitting as compressed as possible to the rotor, just try pushing those together as close as possible because they like to move or
open the bleed valve when you put the clamp on, it might relieve some of the pressure in the piston.
they shouldn't be shot becuase they worked before didnt they?
Old Jan 11, 2007 | 12:50 PM
J9D6M's Avatar
Default Re: (em2ssm02)
Well they were kinda locked up for awhile but seem to be working well recently. Opening the bleerder valve was my next option to try and compress it...Anyone know any other tricks?
Old Jan 11, 2007 | 02:13 PM
91ed9's Avatar
Default Re: (J9D6M)
are there slots on the caliper... if so there is a cude that you put on at it attaches to a 3/8 ratchet that turns back into... i had this problem on my accord but im nto sure if they are oin the crx i havent changed my brakes since i got it orig owner new brakes
Old Jan 11, 2007 | 02:14 PM
91ed9's Avatar
Default Re: (1991 CRX Si)
and also open the bleeder when doing this it makis it alot easier
Old Jan 12, 2007 | 04:38 PM
J9D6M's Avatar
thank you
Old Jan 12, 2007 | 05:57 PM
ozrednsx's Avatar
Default Re: (J9D6M)
for the rear brakes the piston isnt pushed in but twisted back in due to the ebrake mechanism.
what i did was took a screw driver that fits perfect into the cross (+) of the piston and turned it clockwise
worked like a charm...
but the real way there is a special tool for the rear that groves into the piston and you turn it
Old Jan 12, 2007 | 09:32 PM
jstafase's Avatar
i just had to do some work on my rear cy,inders I had to open the bleeder valve to let the brake fluid out of the cylinder to fit my pads on. it might help of you tap it up and down a little casue it might be stuck open.
Old Jan 14, 2007 | 12:08 AM
J9D6M's Avatar
Default Re: Brakes (jstafase)
ok so i opened the bleeder and that bitch aint movin...no way no how...so my next question, should I try and find rear calipers which will prolly be hard as ****, or rebuild the ones I got? Are there any other calipers that will fit?
Old Jan 14, 2007 | 07:13 AM
fireant's Avatar
Do exactly what ozrednsx said. Use a screwdriver shaft to turn the piston clockwise until it bottoms out in the caliper, then unscrew it just enough to get the grooves perpendicular to the caliper so the pad will sit into them. like this: /(+)\
Old Jan 14, 2007 | 09:28 PM
91ed9's Avatar
Default Re: (ozrednsx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ozrednsx &raquo;</TD></TR><TR><TD CLASS="quote">for the rear brakes the piston isnt pushed in but twisted back in due to the ebrake mechanism.
but the real way there is a special tool for the rear that groves into the piston and you turn it </TD></TR></TABLE>
thats what i tried to explain lol ... i ment to say cube*... its a square block
yoyopops
Suspension & Brakes
May 27, 2013 09:07 AM
nicknack25
11
Mar 27, 2013 01:12 AM
95_red_dc
Jun 6, 2006 09:48 AM
95TEG
Jun 11, 2005 07:37 AM
