Motor Mount
Old Jan 11, 2007 | 11:41 AM
Rhood's Avatar
Default Motor Mount
Hi
Can someone tell me how hard it is to change the lower driver side motor mount on a 1998 Civic EX. Mine is broken and the dealer want $190.00 to change it out .
Any help would be appreciated.
Thanks
Old Jan 11, 2007 | 11:43 AM
B18CivicEH2's Avatar
Default Re: Motor Mount (Rhood)
not hard to change the mount the camgears....if you looking for a stock mount, hit up a junkyard and make sure you put your motor on a jack before removing the mount..
if you taking about the mount that goes by the AC Condensor, no need to jack the motor..
Old Jan 11, 2007 | 11:48 AM
Sloshy's Avatar
are u talking about the lower one that is on the a/c bracket if its that one its only two bolt on the frame and one big screw for the bracket, just jack the car up and take the wheel off and youll see how simple it is..
Old Jan 11, 2007 | 12:05 PM
Rhood's Avatar
Default Re: (hatch-E-vanish)
I think so?
Part # 50842-SR3-984 (Rubber L, FR)
Old Jan 11, 2007 | 12:07 PM
gezzuzz's Avatar
Default Re: (Rhood)
don;t buy a new mount.. get a insert.. those mount break easy the new one will break in a few weeks
http://cgi.ebay.com/ebaymotors...58045
Old Jan 11, 2007 | 03:29 PM
Brick Top's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch-E-vanish &raquo;</TD></TR><TR><TD CLASS="quote">are u talking about the lower one that is on the a/c bracket if its that one its only two bolt on the frame and one big screw for the bracket, just jack the car up and take the wheel off and youll see how simple it is..</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz &raquo;</TD></TR><TR><TD CLASS="quote">those mount break easy the new one will break in a few weeks
thats not true. it usually rotts out.
Old Jan 31, 2007 | 06:07 AM
sundownz's Avatar
If you do NOT have AC do you need to keep the mount that goes there? My bushing is totally shredded and I'll leave it off if I don't need it... I plan to upgrade the other mounts.
Anythingbtcivic
Feb 13, 2013 12:37 PM
imadigitalgod
May 29, 2010 11:32 PM
DeeCeeTwo
Jul 19, 2005 11:32 PM
CIVIX
Mar 18, 2002 06:03 AM
