turbo manifold fitment
Old Jan 11, 2007 | 11:21 AM
southcoast integra's Avatar
Default turbo manifold fitment
i have a 96 ls and noticed that there isnt much space between my stock headers and the radiator. if i install a turbo set up, do i need to relocate the radiator?
Old Jan 11, 2007 | 11:23 AM
Boots's Avatar
Default Re: turbo manifold fitment (southcoast integra)
first, you have one header, second no you dont need to move anyhting unless youre getting rid of ps and ac
edit: after looking at your post again...where the hell would you relocate it to?
Old Jan 11, 2007 | 12:20 PM
Topher.'s Avatar
Default Re: turbo manifold fitment (boots)
Most likely you won't need to move it.....even tho like boots said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boots &raquo;</TD></TR><TR><TD CLASS="quote">where the hell would you relocate it to?</TD></TR></TABLE>
If anything you could always replace the full sized radiator for a dual core half rad.
Although with a turbo setup...your biggest enemy is heat.
If you decide to go half sized....please invest in a good radiator and not some cheap POS
Old Jan 11, 2007 | 12:34 PM
DS002's Avatar
Banned
Default Re: turbo manifold fitment (B92P_DC2)
It depends , if your using a ram horn you need to go half size . If its a log you just need a slim fan , or you can remove the condenser fan and move it into the the cooling fans spot and do away with the full size fan completly . It works on my turbocharged integra and it never overheats or gets hotter than it was stock .
Old Jan 11, 2007 | 12:44 PM
lVlemphizStylez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B92P_DC2 &raquo;</TD></TR><TR><TD CLASS="quote">
If you decide to go half sized....please invest in a good radiator and not some cheap POS</TD></TR></TABLE>
No...There are tons of people using the POS Civic radiator in boosted Teg's and don't experience overheating problems...
Old Jan 11, 2007 | 03:53 PM
Topher.'s Avatar
Default Re: turbo manifold fitment (lVlemphizStylez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">
No...There are tons of people using the POS Civic radiator in boosted Teg's and don't experience overheating problems...</TD></TR></TABLE>
I believe you.....yet at the same time you cannot deny the increased risk of overheating.
Old Jan 11, 2007 | 04:57 PM
DS002's Avatar
Banned
Im not even using a full size fan , im using my A/C fan to cool my radiator . I mean yea theres definitly risks involved , just keep an eye on the temp gauge the first few times you take it out and everything should be fine . My car runs real cool , which suprised me a lot .
Old Jan 11, 2007 | 05:23 PM
slowb20boost's Avatar
WELL GOOD LUCK WITH THAT
Old Jan 11, 2007 | 06:37 PM
hks369's Avatar
screw the a/c roll down the windows
Old Jan 11, 2007 | 06:44 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: turbo manifold fitment (hks369)
B92P_DC2m, the link in your sig is not working
Old Jan 11, 2007 | 07:51 PM
Topher.'s Avatar
Default Re: turbo manifold fitment (It's*BOLO!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by It’s*BOLO!! &raquo;</TD></TR><TR><TD CLASS="quote">B92P_DC2m, the link in your sig is not working</TD></TR></TABLE>
thanks for the heads up.....
fixed
Old Jan 11, 2007 | 08:17 PM
Schister66's Avatar
Man U FTW
I ran my original turbo setup w/ the stock full length radiator, but there are only certain manifolds built to fit like that....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">No...There are tons of people using the POS Civic radiator in boosted Teg's and don't experience overheating problems...
With my new topmount i'm using one of those POS Civic Si radiators and haven't had any problems either....maybe they're not such crappy units afterall....
Old Jan 11, 2007 | 08:56 PM
aaronISthrowed's Avatar
Default Re: (Schister66)
It's a tight fit but it works, just use a log manifold. (inline pro)
Old Jan 11, 2007 | 09:40 PM
qfast817's Avatar
Default Re: (aaronISthrowed)
or buy my ramhorn
Old Jan 11, 2007 | 11:35 PM
teknoracing's Avatar
Use the smaller radiator from a civic.
Old Jan 12, 2007 | 08:38 AM
red_crx's Avatar
Default Re: turbo manifold fitment (teknoracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DS002 &raquo;</TD></TR><TR><TD CLASS="quote">It depends , if your using a ram horn you need to go half size . If its a log you just need a slim fan , or you can remove the condenser fan and move it into the the cooling fans spot and do away with the full size fan completly . It works on my turbocharged integra and it never overheats or gets hotter than it was stock . </TD></TR></TABLE>
Not all true...you can use a full length radiator with the Neukin a/c compatible ram horn as well as Full Race's RR version.
90edhb
10
Oct 5, 2009 11:02 PM
totsie7944
Oct 9, 2008 12:23 PM
savedone
Oct 21, 2006 12:39 PM
AspectIndustries
Oct 16, 2003 10:05 AM
sneakypete
Jan 13, 2003 10:31 AM
