Engine running but car won't move (help)
I'm on the freeway driving to work when all of a sudden I lost power at the wheels. The engine is still running but the car won't move when I put it on first gear.
So I towed it to my mechanic and he showed me that the passenger axle wasn't in all the way. So he snapped it back into the tranny. Started the car and put it on 1st gear. It worked! So then I go back to the freeway then It happened again! Engine running but no momentum. I can rev the engine and can see the tach needle going up and down as I rev.
Can it be the tranny? Can somebody help a fellow g2 owner out? Thanks
Most likely a bad axle/retaining clip. It "could" be the diff not allowing the clip to pop in like it should, but thats somewhat unlikely. Replace the little C' clip and see if that helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cinhatch »</TD></TR><TR><TD CLASS="quote">Hey everyone i have a GSR in my civic but the crank position sensor is bad where is that located exactly? im sure its near the crank pully but i cant find it..</TD></TR></TABLE>
damn find your own thread.
can you still feel your clutch engaging??? check in order..
engine>clutch/flywheel>tranny>axles>wheels
at least thats the order i would troubleshoot this problem
how did you fit a a "GSR" in a civic?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHTFP »</TD></TR><TR><TD CLASS="quote">
damn find your own thread.</TD></TR></TABLE>
no ****. thats rude.
Kevin D
Sep 12, 2018 12:43 PM
leviathan4444
16
Jul 11, 2006 10:17 PM
Re3irth
Jul 12, 2004 12:23 PM
Sassafrass
10
Aug 28, 2003 12:13 PM
