Power steering by-pass!!! sorry to bring this back up!
Old Jan 11, 2007 | 09:46 AM
seelyd's Avatar
Default Power steering by-pass!!! sorry to bring this back up!
I have done alot of searching on this topic and I have read I'm pretty sure all of the posts on this site but I am still a little uneasy. I would really like to do this to my 91 EXR, I don't have a problem with a little stiffer steering and I like the benifits of less weight and less parrasitic drag on the engine. The ONLY issue I have with this is the long term effects on the steering rack. There has been alot of mixed opinions on this mod, mostly about the added difficulty with steering. I just want to know if this is going to damage my steering rack with long time use. Sorry again for bringing this topic up again!! Thanks
Old Jan 11, 2007 | 05:00 PM
H22isnotabigblock's Avatar
Default Re: Power steering by-pass!!! sorry to bring this back up! (seelyd)
ive done this mod on numberous cars with no adverse results, but you have to remember to fill the rack with PS fluid and loop the lines together.
it will get dry ruin the rack if it is run dry
Old Jan 12, 2007 | 02:16 AM
seelyd's Avatar
Default Re: Power steering by-pass!!! sorry to bring this back up! (H22isnotabigblock)
Is there anyway to add fluid to the rack after the lines have been looped in case any leaks out after the mod? Can you just add fluid through the resovior??
Old Jan 12, 2007 | 04:29 AM
TouringAccord's Avatar
H-T Order of Merit
well, by your last post I would have to think you might have missed these then.
How-To: power steering to manual
Power Steering Removal and Remote Reservoir Parts
I know it's all related to Integras but the info is useful.
Those both can be found in the Accord FAQ as well.
Old Jan 12, 2007 | 09:58 AM
seelyd's Avatar
Default Re: Power steering by-pass!!! sorry to bring this back up! (TouringAccord)
Thanks! I have read both of those posts but the plumbing on my rack is different from those, obviously because they are both integra's. I know which lines are the pressure line and low pressure line from the pump and the fluid cooler but there are two other lines that go to a senor on the tranny, I think that they are for increasing pressure at low speeds but I'm not 100% sure. I'm going to try this mod either way seeing as it is easily reversed but I'm just trying to get as much knowledge as possible before going ahead with it. Thanks again!!
Old Jan 12, 2007 | 03:51 PM
H-T Order of Merit
oh, I thought you looked familiar, you already started a thread on this topic. Next time, instead of starting another thread for the same general thing, just keep posting in your original thread.
So what is your question exactly?
If you know what is you high and low pressure, those threads tell you which one you need to "T" into. And you other thread already answered your question about those other lines, just loop them.
danteisme
Jan 23, 2017 08:31 AM
Axatax
Sep 28, 2013 01:56 AM
732xghost
Nov 5, 2009 01:09 PM
mattcalica
Jun 29, 2004 11:10 PM
