b17 head on b16 block
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEg »</TD></TR><TR><TD CLASS="quote">any b series head is interchangeable with another b series head..</TD></TR></TABLE>
incorrect
but yes that will work!
incorrect
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz »</TD></TR><TR><TD CLASS="quote">
incorrect
but yes that will work!</TD></TR></TABLE>
what B series heads ARENT interchangeable???
besides NON Vtec heads on Vtec blocks???i mean, that should be obvious....
incorrect
the b20a are not compatible
besides NON Vtec heads on Vtec blocks???i mean, that should be obvious....</TD></TR></TABLE>
yes you can put a ls head on a b16a block.. people do it all the time..
throw in a crx with 150 shot you got a cheap track car..
motor blows who cares you made it from scraps
me
you
lol
me
you
lol
ok...well, that something new i learned today about throwin a ls head on a b16 block... but was this really necessary??
me
you
lol
its not like if this is a competition on who has the best right answer..
me
you
lol
</TD></TR></TABLE>its not like if this is a competition on who has the best right answer..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RYan McG. »</TD></TR><TR><TD CLASS="quote">will a b17 head work on a b16 block?</TD></TR></TABLE>
I believe B16, B17 and Type-R all share the same head (Type-R has mild factory porting).
GSR is different than the rest. It will still bolt on, but your compression will change.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz »</TD></TR><TR><TD CLASS="quote">my bad.. just having a little fun.. </TD></TR></TABLE>
f'sho...im surprised you didnt get all butt hurt about a little discussion like this...usually peeps get their panties in a tight grip and start e-thuggin...
to you....on with the techin'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Projekt_2nr »</TD></TR><TR><TD CLASS="quote">yeah but you'll need a totally different head gasket</TD></TR></TABLE>no!!
thay all use the same gasket(vtec)
you'd basically be swapping one head for the exact same one with maybe a different vavletrain. what's the point?
unless you dont have a head on the block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtec_Dragun »</TD></TR><TR><TD CLASS="quote">the gs-r heads are not interchangeable due to the dual butterfly in the intake manifolds.
also i think the b16a head has more compression then the b17</TD></TR></TABLE>This is false.
b16a,b17a,b18c5 are the same heads and then dont add more compression.
only the gsr(b18c1)will add .2 of compression
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RYan McG. »</TD></TR><TR><TD CLASS="quote">lol. thanks you guys have been alot of help. what would the advantage of b17 head vs. b16 head on b16 block?</TD></TR></TABLE>
nothing significant.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtec_Dragun »</TD></TR><TR><TD CLASS="quote">the gs-r heads are not interchangeable due to the dual butterfly in the intake manifolds. </TD></TR></TABLE>
and what would that have to do with bolting the head to the block? nothing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">also i think the b16a head has more compression then the b17</TD></TR></TABLE>
you're 0 for 2
you're 0 for 2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicex442 »</TD></TR><TR><TD CLASS="quote">what is the b17 off of?</TD></TR></TABLE>
92-93 GSR
92-93 GSR
Chekz
Apr 19, 2007 09:11 AM
caminSi
Mar 31, 2006 11:18 AM
Stock@$$GSR
Oct 18, 2004 06:51 PM
paybac4223
Mar 24, 2004 03:29 PM
