Emanage Ultimate on FD1A
Hi guys:
anyone tried installed Emanage ultimate on FD1A with R18 yet?
I tried and it's working, but i found some problem after 3 days driving with it.
wiring done according to the user manual, I didn't connect VTEC control, from my understand, R18 with E-throttle able to open up the throttle during cruising and delay intake valve open timing. so leave it first.
during the software setup, there is no R18 update in E-ultimate yet from V.2.0, so i choose K20, and initially engine able to start, working fine. but after 3 days, the CEL suddenly out, and when i on my ignitiong switch without start engine, the gear idicator shows I'm in P, but the indicator for D keep blink. can feel RPM not smoothly going up especially at 2000RPM range.
Tried to use BOD2 scan tool, but didn't display any error code for that CEL, after reset ECU, everything's fine.
any guru here able to help me?
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vic000 »</TD></TR><TR><TD CLASS="quote">Hi guys:
thanks</TD></TR></TABLE>
Comment #1 - This is hard to follow.
Comment #2 - No offense, but this is what happens when you use something not made for what you want to do. The application has everything to do with it. It is made for K20 and you have R18. 2 different engines. Also, I would envision the ECU's being different as well. Hence the cells going out.
I get my R18 ECU wiring from one of my japanese friend whom had a workshop there.
It's a little bit diff between K20z and R18A as pin location. sockets are the same
now my situation:
ECU showed CEL on, gear D indicator blinks while in P gear.
I got no idea what does that mean. no clue to solve the problem. not at least let me know where i did wrongly.....
anyone can help? OBD2 scan tool unable to tell why CEL is on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vic000 »</TD></TR><TR><TD CLASS="quote">now my situation:
anyone can help? OBD2 scan tool unable to tell why CEL is on</TD></TR></TABLE>
Do you have some sort of wiring diagram for the R18?
yup, in japanese.
what we need for ultimate is pressure sensor, +-V, RPM, ignition for each channel, TPS. VTEC i leave it originally, as from honda, they claimed of the E-throttle issue.
and there are 2 TPS signal, one is from driver's input, the other one is actual throttle operate by ECU.
vici0us
Mar 21, 2011 05:40 PM
johnwohl
17
Apr 6, 2009 05:58 AM
A down pipe as exhaust manifold.
