Short Shifter Questions
Old Jan 10, 2007 | 08:53 PM
xluben's Avatar
Default Short Shifter Questions
I just ordered a short shift adapter:
http://cgi.ebay.com/ebaymotors...d=1,1
and I realize that all it's doing is moving the load (linkage) to a higher point on the shift lever (closer to the center of rotation).
Basic lever principles in action. It shortens the throw, but also increases the force necessary to actuate.
What i was wondering is, why doesn't anyone make an adapter that will move the load MUCH further down the lever (1"+) and make the throw a lot shorter?
What kind of problems will this cause? It seems like the only issue would be excessive strain on the adapter.
Thanks for any insight!
(Also, does anyone have info on how the "real" short shifters work to shorten the throw?)
Modified by xluben at 4:16 AM 1/11/2007
Old Jan 10, 2007 | 09:55 PM
specbb6's Avatar
Default Re: Short Shifter Questions (xluben)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">(Also, does anyone have info on how the "real" short shifters work to shorten the throw?)</TD></TR></TABLE>
this is what I found at the pspec ss site: <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">http://www.pspectuning.com/9497accord_short_shifter.php
The short throw shifter works in two ways. First, by reducing the actual height of the unit. The shorter the shifter is, the less distance it has to travel to get into and out of gear. Secondly, by moving the position of the shift cable. By placing it higher up on the shift lever, it allows for quicker, more solid, crisp shifts into every gear.</TD></TR></TABLE>
Old Jan 10, 2007 | 10:54 PM
Heinekenf22's Avatar
get PSPEC!!!!!!! adapters SUCK. i gotta dc adapter it sucks *****
Old Jan 11, 2007 | 03:15 AM
xluben's Avatar
Default Re: Short Shifter Questions (specbb6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specbb6 &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.pspectuning.com/949...r.php
well the short shift adapter cover the second part (moving the point where the shift cable attaches to the level).
in my mind it seems that well made adapter bracket and cutting down the shift lever should perform as well as an entire new assembly, unless i'm missing something.
i'm still wondering why they don't make an adapter that will move the shift cable attachment point a lot and thereby shorten the throw a great deal.
Old Jan 11, 2007 | 03:20 AM
TheMuffinMan's Avatar
He knows where you live!
Most of people's worries with ebay adapters and what not is the quality, it's really hit or miss with them. I would suggest throwing down some money on it. Just looking at the craftsmanship the Pspec ones looks like it's 20 times better materials wise than the ebay one. It's really up to you though
ProjectCD5
Feb 21, 2006 11:55 PM
starbury
Feb 15, 2005 09:58 AM
ketchup
17
Aug 26, 2004 08:42 AM
Modifiyem
Jul 31, 2003 06:30 AM
ArchAngel Sabastian
Feb 2, 2002 12:09 PM
