capacity of the stock fan relay???
i'm going to be installing a new perma-cool fan that draws 7.5amps and uses a 30amp fuse. i want to try to use the factory fan relay but i need to know how much current the factory fans pull. is it safe to to use it for this fan or do i need to wire a larger relay?
Rah Rah
Jun 3, 2004 06:08 AM
So you should be fine
