99 Accord Black Headlights (eBay)
Old Jan 10, 2007 | 08:08 PM
xluben's Avatar
Default 99 Accord Black Headlights (eBay)
Are any of these headlights worth the $100?
Not looking for added performance, just upgraded looks (and one of mine is VERY dirty inside, and I can't clean it).
http://cgi.ebay.com/ebaymotors...d=1,1
When it says "JDM headlight" is that "JDM-style" or an actual brand name?
Are these direct drop-in's from stock (same bulbs)?
How hard are they to change (screws, etc.)?
If there's anything I should look out for (good or bad) please let me know!
Old Jan 10, 2007 | 08:29 PM
4drH22Accord's Avatar
Default Re: 99 Accord Black Headlights (xluben)
yeah, I have them on my car and love the look. I actually have two sets. I tinted one set yellow for the jdm look and kept the others black. Here are a few picks.
Old Jan 10, 2007 | 08:36 PM
xluben's Avatar
Default Re: 99 Accord Black Headlights (4drH22Accord)
i really like the look in the second pic. not so sure about the yellow ones though.
are they easy to install?
any problems with their functionality?
can you suggest an ebay seller to buy from (there's so many)?
Old Jan 10, 2007 | 08:44 PM
shibbywhitedude's Avatar
I would go with the last store since they have 99.9% positive feedback. JDM means JDM style... Yes they are direct plug-in I'm sure since my Ebay lights were but I'm not sure that they will fit perfect since they are off ebay. Mine did but ya never know, I'm sure they will. To put them in you will have to remove the front bumper cover and take some screws out, not too hard, too me a couple hours to do all of it.
Old Jan 10, 2007 | 08:55 PM
xluben's Avatar
Default Re: (shibbywhitedude)
any links to the headlight change (bumper removal) process?
Old Jan 10, 2007 | 08:57 PM
Default Re: (xluben)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xluben &raquo;</TD></TR><TR><TD CLASS="quote">any links to the headlight change (bumper removal) process?</TD></TR></TABLE>
I'll have to see. I used my Hanes book to do it. If I can't find anything and no one posts before I can do it, I'll type out how they say to do it in the book.
EDIT: Okay, I'll try my best at explaining this... Before you do anything, disconnect the battery and let it sit for about 5 minutes so you don't set off your airbags. IMPORTANT: Your stereo is equipped with an anti-theft system. Make sure you have the correct activation code before disconnecting the battery... (only if it's the stock stereo). Next pop the hood, easy right? Look between the headlights on the top of the grille (where the H is in the center) and you will see 2 black clips on either side. Use a flatblade screwdriver or whatever you prefer and pop those up or unscreew them, however yours are. Next, detach the screws securing the lower edges of the bumper cover. There will be several of these underneath the car running from one side to the other. Note: Use a small screwdriver on these screws to pop the center button up, but do not try to remove the center buttons. They stay in the ferrules. The last 2 bolts holding the bumper cover on are in the fenders at the top of where the sides mount inside the fenders.They are easy too see. Unscrew those and carefully remove the bumpercover. The headlight housings will be easy from there as you will be able to see the few screws that hold it in. I'm sorry I don't have pictures. Again, if no one helps you by tomorrow, I can take pictures detailing this tomorrow after work.
Modified by shibbywhitedude at 10:12 PM 1/10/2007
Modified by shibbywhitedude at 10:14 PM 1/10/2007
Modified by shibbywhitedude at 10:23 PM 1/10/2007
Old Jan 10, 2007 | 09:19 PM
xluben's Avatar
thanks a ton!
pics would be helpful to find all the screws.
i'll have to take a look at my bumper tomorrow.
Old Jan 10, 2007 | 09:25 PM
Okay, I'll snap a couple tomorrow and you can see how my headlights look. I got the Ebay projector/halos... they're alright, but if I could do it again, I'd go for something like you're looking at.
Old Jan 10, 2007 | 09:54 PM
Defcon1's Avatar
I will be baking my headlights this weekend thanks for the info... any suggestions for baking are welcome as well... cannot be to careful
Old Jan 11, 2007 | 09:14 AM
Crono139's Avatar
Very easy to swap out. Here's a DIY for doing blackhousings, so just skip the baking / painting parts. http://www.filtsai.com/accord/housings/index.php
I basically have the same ones, but I got mine through ProCarParts.com. They have an eBay store as well.
Fitment was spot on, but if you are using HIDs, the output is a bit more scattered with a few hotspots. You won't notice with halogen bulbs.
Old Jan 11, 2007 | 12:10 PM
Defcon1's Avatar
Default Re: 99 Accord Black Headlights (Crono139)
misspell something? cause that link is dead for me
Old Jan 11, 2007 | 12:20 PM
Default Re: 99 Accord Black Headlights (Defcon1)
I'm confused... Who's this thread for? Xluben or Defcon?... Anyways that link worked for me just fine...
Old Jan 11, 2007 | 12:56 PM
Crono139's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Defcon1 &raquo;</TD></TR><TR><TD CLASS="quote">misspell something? cause that link is dead for me</TD></TR></TABLE>
Try this then. http://www.filtsai.com/accord/housings
And the thread belongs to xluben.
Old Jan 11, 2007 | 01:29 PM
concept11253's Avatar
I purchased the JDM halo projectors in the beginning of last year. They are just ok. I think if I had to do it again, I would just black out my stock lights. The projectors don't throw enough light for me. I guess if you dropped HID's in them they would be pretty sick. Well I took pictures of my install and you can look at the pictures and you should be able to install them.
Picture of the location of the top bumper clips.
The location of the bumper clips on the bottom
Screw located in the wheel well. (8mm Socket)
Screw located on the bottom of the bumper near the wheel well (10mm socket)
Removal procedure of the bumper clips. Use a flat head screwdriver. Becareful as they do break!
Location of the screws that hold the headlight in. ( I don't remember the socket size off hand. Might have been a 14mm)
It should come right out. But take it out slowly and disconnect the wires to the head light.
Final product!
Modified by concept11253 at 8:53 PM 1/11/2007
Old Jan 11, 2007 | 04:35 PM
Defcon1's Avatar
Default Re: 99 Accord Black Headlights (concept11253)
Thread is not for me, I just happen to be doing the same thing this weekend, except i am baking my headlights to modify them and I think Xluben is replacing his...
Got the link btw, thanks!
Old Jan 11, 2007 | 07:34 PM
SuShiBoiiii's Avatar
good write yo concept111253 wish someone did that for the 5th gens
Old Jan 11, 2007 | 10:41 PM
ex95cord's Avatar
Default Re: 99 Accord Black Headlights (SuShiBoiiii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuShiBoiiii &raquo;</TD></TR><TR><TD CLASS="quote">good write yo concept111253 wish someone did that for the 5th gens </TD></TR></TABLE>
I'm sure someone has somewhere...same process though, gotta take the whole bumper off, it sucks.
Old Jan 11, 2007 | 11:15 PM
Default Re: 99 Accord Black Headlights (ex95cord)
the only hard part is the bolts under the headlights
Old Jan 12, 2007 | 12:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuShiBoiiii &raquo;</TD></TR><TR><TD CLASS="quote">the only hard part is the bolts under the headlights </TD></TR></TABLE>
You need to get a socket wrench extension then its not a problem.
camacho9555
Nov 16, 2009 03:05 AM
ABK
27
Nov 29, 2007 12:29 AM
Importn2oRacer
Oct 20, 2007 10:33 AM
Namdaman
Feb 14, 2005 09:41 PM
chasnjason
Oct 30, 2003 10:48 AM
