HIDs problem PLEASE HELP
I just got a plug and play HID kit. I wired everything up correctly but the only problem is that the HIDs will only turn on in highbeam mode, not on regular. I know I have a single beam H4 kit. How do I fix so that the HID will turn on without being in HID mode?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hkboy87 »</TD></TR><TR><TD CLASS="quote">its a plug that fits perfectly into my h4 headlight harness...and there is only one way to fit the harness into the OEM harness</TD></TR></TABLE>
Take pictures please. You may just have to repin it.
i'll take pictures soon...in the mean time i'll try to describe it
the OEM harness is a female three prong plug and the HID harness is a male three prong plug
its basically like plugging something into your house power outlet...it only fits one way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hkboy87 »</TD></TR><TR><TD CLASS="quote">i'll take pictures soon...in the mean time i'll try to describe it
its basically like plugging something into your house power outlet...it only fits one way</TD></TR></TABLE>
You'll need to find out which wire is the ground, and then switch the other two.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hkboy87 »</TD></TR><TR><TD CLASS="quote">also one last question..do the bulbs change color as you use it longer?
i got a 8k kit and it looks factory hids..i was hoping for something a little more blue</TD></TR></TABLE>
As the halides get hotter, they'll burn their true color, but this should happen during normal operation, not over a span of time.
