93 dx with b18a swap having problems with accelerator cable.
Old Jan 10, 2007 | 04:56 PM
stackz's Avatar
at the jetties fishin'
Community Builder
Default 93 dx with b18a swap having problems with accelerator cable.
got the 91 b18 in my 93 dx and I'm using the 91 LS throttle cable. It's got like 2-3" of slack in it??
any way to take up this slack?? I see an adjustable section at the intake manifold mount but it doesnt look to be near enough.
Old Jan 10, 2007 | 04:59 PM
gezzuzz's Avatar
Default Re: 93 dx with b18a swap having problems with accelerator cable. (stackz)
you need to rig the bracket.. use one screw flip it around or some thing..
Old Jan 11, 2007 | 03:57 AM
stackz's Avatar
Community Builder
Default Re: 93 dx with b18a swap having problems with accelerator cable. (gezzuzz)
there's not a throttle cable that will work for this without having to modify anything??
Old Jan 11, 2007 | 04:03 AM
big-cat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz &raquo;</TD></TR><TR><TD CLASS="quote">you need to rig the bracket.. use one screw flip it around or some thing..</TD></TR></TABLE>
yeah your going to want to use your imagination with the throttle cable bracket. but if its only held on by one bolt, have a lock washer and tighten it down damn good. good luck. u can flip it and slide it(sounds good if u do it on a girl). either or good luck
Old Jan 11, 2007 | 06:19 AM
Andres-eh2's Avatar
I used a 93 DA one before and worked no problem. I would think 90-93 are all the same unless they have different brackets from 90-91 to 92-93 on the IM
Old Jan 11, 2007 | 11:17 AM
stackz's Avatar
Community Builder
Default Re: (Andres-eh2)
alright, I'll give it another try. I'll flip the bracket around.
also, there's a rubber bushing like part that's about 1.5" long right behind the metal portion and then behind that it looks like a yellow clip. I'm wondering if all of that has to go past the pedal notch. probably where all the slack came from.
it's been like 8 months since I pulled all the LS components from the car so I dont remember too good how it went in.
Old Jan 15, 2007 | 10:50 AM
92greensleeper's Avatar
Default Re: (stackz)
Well I have the same setup in my 92 dx and I'm running a 94 ls cable it works perfect.....but yeah I'm almost positive that black rubber spacer is what's your problem, unhook the front and hook the pedal side up first, savvy?
801mobbin
Jan 28, 2016 09:34 PM
hellajdm333
Feb 15, 2010 01:32 PM
wildRHDeg6
Jul 29, 2008 06:24 PM
loclowd
Jun 14, 2005 05:51 PM
OreoEF8
Mar 31, 2004 07:41 AM
