Throttle cable problem!!!
Ok so i installed a JDM B18C in my 93 civic 4dr. The motor has a Skunk 2 pro manifold and 66mm TB. The problem is i dont know what throttle cable to use. I have an LS cable and a GSR cable. I also have a single cam, LS, and type r cable bracket. Which cable should i use?
Brandon
Brandon
Ok so i got the bright idea of taking the type r bracket, measure out two new holes and drill them. Then you can use the LS cable and it works perfect. Just another idea.
