Funciton 7 block girdle
Old Jan 10, 2007 | 04:15 PM
5thgearburnout's Avatar
Default Funciton 7 block girdle
What does everybody think ther block girdle? I was also wondering if b18b main studs will work with ther girdle? I searched but couldnt find anything.
Old Jan 10, 2007 | 04:24 PM
non-VTEC's Avatar
Default Re: Funciton 7 block girdle (5thgearburnout)
im pretty sure you need the long GSR main bolts to fit that girdle on the bottom end with that girdle. you will need all 10 of them too.
Old Jan 10, 2007 | 04:45 PM
doood's Avatar
been there done that
Default Re: Funciton 7 block girdle (non-VTEC)
and you'll probably also need the gsr windage tray, pickup, and pan.
Old Jan 10, 2007 | 05:15 PM
litovi3tboi503's Avatar
Default Re: Funciton 7 block girdle (doood)
wondering the same thing.. will you need machining the dowels for the main caps like the erl 5 main girdle?
Old Jan 11, 2007 | 05:38 AM
newspeedR's Avatar
Default Re: Funciton 7 block girdle (litovi3tboi503)
The dowels for the mains are stepped so no extra machining is required...
https://honda-tech.com/zerothread?id=1660734
zedron
Jan 16, 2010 01:42 PM
bassplayer
Aug 15, 2009 06:34 AM
BlackThorN
Feb 6, 2004 12:03 AM
JDM EG
Jan 20, 2002 05:06 PM
