GSR block girdle on a LS??
Old Jan 15, 2002 | 12:12 PM
JDM EG's Avatar
Default GSR block girdle on a LS??
Will this work? I am building an LS/VTEC and have heard of people using this method. Has anyone on this board done this? If you have, do you just reuse the GSR main bolts? Thanks..
Old Jan 15, 2002 | 12:21 PM
HX_Guy's Avatar
Default Re: GSR block girdle on a LS?? (JDM EG)
You mean like this
Use a GSR girdle, oil pan, oil pickup, baffle and GSR the main cap bolts for the 3 middle caps.
Old Jan 15, 2002 | 12:40 PM
One8Hatch's Avatar
New User
how does a block girdle help support the internals so you'd be able to rev higher safely?? from what i can see it just bolts under the main caps? thanks
Old Jan 15, 2002 | 12:50 PM
HX_Guy's Avatar
Default Re: GSR block girdle on a LS?? (One8Hatch)
Its supposed to help the main caps from moving
The girdle is like a brace, a reinforcment
Higher RPMs = more vibration
Old Jan 15, 2002 | 01:02 PM
Shft@9GSR's Avatar
Using a GSR block girdle on an LS block pretty much makes it a GSR block. You have to use gsr windage tray, pickup and pan to complete the setup. I am having mine done as we speak.
Old Jan 15, 2002 | 02:25 PM
JDM EG's Avatar
Default Re: GSR block girdle on a LS?? (HX_Guy)
Thank you!!
Old Jan 15, 2002 | 05:36 PM
JCushing's Avatar
is the z-10 block girdle any better or worse?
Old Jan 15, 2002 | 05:58 PM
non-VTEC's Avatar
Default Re: GSR block girdle on a LS?? (JCushing)
the Z-10 girdle is more stronger/solid and does not need modifications to fit..... but cost's alot more than a B18C block girdle.
a block girdle NEW from the dealer is just under 100 bucks...........but you will still be needing those other parts as well (6 GS-R main bolts, GS-R oil pump pick-up, GS-R windage tray, GS-R oil pan......)
i guess if you were going to make some super crazy 700+ hp engine the stronger Z-10 girdle would probably be a better choice. but for what most people use them for the B18C girdle is plenty strong.........
Old Jan 15, 2002 | 06:09 PM
JCushing's Avatar
Default Re: GSR block girdle on a LS?? (non-VTEC)
well you still need all those gsr parts to make it z-10 one work right. i think however if its good enough for a gsr it would be good enough for a gs (me). im going turbo but i doubt ill rev past the stock reline so the gsr girdle might be good for a little extra protection if i rebuild.....
Old Jan 18, 2002 | 11:03 PM
crxfactor1991's Avatar
what exact mods need to be done to the gsr girdle to make it fit?
Old Jan 19, 2002 | 07:47 PM
non-VTEC's Avatar
Default Re: GSR block girdle on a LS?? (crxfactor1991)
the middle main cap has to be machined down so that it's almost equal to the other main caps..........that is supposed to be the BEST way to put a GS-R girdle on the LS engine.......HXguy had the girdle itself modified to fit which is OK but some people might not agree with it and will say that the girdle looses some strength by doing so............
Old Jan 20, 2002 | 05:06 PM
thanks for the info...ill have to check it out
should i have the bottom part of the middle main cap machined down to look exactly like the others?
grand champ
12
Jul 14, 2007 03:57 PM
Simple
Aug 22, 2005 08:04 AM
SM 30 Hatch
Oct 7, 2004 04:12 AM
reddevil94
Jun 4, 2004 12:13 PM
Speedz
Aug 16, 2002 05:19 PM
