Block Girdle???
Old Feb 5, 2004 | 08:14 PM
BlackThorN's Avatar
Default Block Girdle???
How many of you guys with a Stock LS engine running 11psi of boost are not using a Block Girdle? I was wondering if this is a very important upgrade or if it is not necessary
Old Feb 5, 2004 | 08:21 PM
shermanyang's Avatar
Default Re: Block Girdle??? (BlackThorN)
15 lbs daily...and no block girdle
Old Feb 5, 2004 | 08:33 PM
Mark817teg's Avatar
To add on to this post, how exactly does the block girdle work? Ive never seen the under side of one. it it essentially 3 (or 5) main caps cast into one, or does it bolt to the existing main caps? What im getting at is what bolts do you use and do the bearings ride in the girdle?
Whats included when you buy one new?
Also if im usin main studs to I need longer ones? are they offered?
Old Feb 6, 2004 | 12:03 AM
Toda Built's Avatar
Default Re: (Mark817teg)
https://honda-tech.com/zerothread?id=735877
ask Lightning>>(tom) he will tell you everything you need to know
96Dc2 GSR
Sep 6, 2012 11:01 PM
downest
May 20, 2006 08:55 PM
riceball777
Nov 27, 2004 09:30 PM
riceball777
Nov 27, 2004 04:13 PM
