Compression Leak Problem
Old Jan 10, 2007 | 02:51 PM
Tru's Avatar
Tru
Default Compression Leak Problem
I have a D16Y8 with a full Crower head and pnp and an edelbrock Intake Manifold. I recently put the head on, and i know the car is going to lope at idle, but it wouldnt even idle and would shut off when the rpm's dropped. I did a cylinder leak test, and cylinders 1, 2, and 4 were fine. cylinder 3 had a 50% leak out of the intake, mind you these are brand new valves, with a new valve job, etc. I've ruled out a bent valve or a messed up valve seat, because it works fine when cold (and wont leak when cold), but when it warms up, starts to mess up. Does anybody here have an idea of what it could be? Ive been looking into this all day, and its driving me insane. Thanks in advance,
Nick
Old Jan 10, 2007 | 02:55 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: Compression Leak Problem (Tru)
maybe a seating problem or rings ...
Old Jan 10, 2007 | 03:17 PM
Tru's Avatar
Tru
im leaning towards a seating problem, because the bottom end was fine when we pulled the old head off. my question about the seating problem is, why would it not act up all the time, and only when warm?
Old Jan 10, 2007 | 04:49 PM
aaronPratt's Avatar
Default Re: (Tru)
only warm because metal expands when it gets warm. check those valves again when the motor is still hot. or any where for a leak when the motor is hot. the thing that works for me is some verry soapy spray. and sypay it aroung some seals when runing. if it bubbles then u have a prolbem. be shure and carfull not to get it into the engine!
Vowels771
16
Jul 6, 2019 03:21 PM
y2kferari
Nov 28, 2009 11:39 AM
Boostedb20EH2
10
Apr 23, 2007 06:11 PM
1fast5gp
Mar 22, 2003 01:58 PM
COREY ITR#625
May 21, 2002 12:20 PM
