crx won't turn over, battery and starter check ok
Ok heres the deal, normally i can figure stuff out on my own, however I feel that I have exhausted all possible options. The car is a crx with a b16 swap, has been running fine for over a year since i got it. I went out of town for the holidays, get back and go to start it and i just here a click (starter solenoid). I tried to jump it off with my other car and it just gives the "click". I check the ground from the battery to the tranny, its good, voltage from battery to starter is good, so i jumper a wire from the positive terminal to the starter solenoid, "click". Ok easy enough, the starter is bad, went and got another one, popped it in....whaddya know, "click". For some reason the starter will not turn the flywheel. I jacked the car up, turned the crankshaft and there is no more force than normal required to turn the crank. I know the crank and flywheel are connected on the other end, so why won't the damn thing turn over????? any help would be appreciated.
P.S. the only thing i have not tried to do is push start it, hopefully if I can get a friend over tonight I will try that.
