Hasport Mount Question
Old Jan 10, 2007 | 01:51 PM
JFG Kevin's Avatar
Default Hasport Mount Question
i was just wonder can I take out the TQ mounts for my DB if i have Hasport mounts? I was going to take off the tranny and the block side mounts. But then i'm not sure if the mounts will hold up to that, the motor is making 220whp and 150lb tq. Would it be ok?
Old Jan 10, 2007 | 03:21 PM
doood's Avatar
been there done that
Default Re: Hasport Mount Question (JFG Kevin)
i dont think you'll even be able to use those mounts with the hasports
Old Jan 10, 2007 | 08:10 PM
95 integra's Avatar
Default Re: Hasport Mount Question (doood)
You mean take out the lower torque mounts all together and leave them out? But why?
Old Jan 11, 2007 | 11:25 PM
JFG Kevin's Avatar
Default Re: Hasport Mount Question (95 integra)
My lower tq mounts are all ripped...so to me i have no point in puttin them back. Plus the hasport should be strong enought to hold the motor should it?
Old Jan 12, 2007 | 07:33 AM
95 integra's Avatar
Its not a matter of holding the engine in, its a matter that the tq mounts are the main mounts the prevent wheel hop and prevent the motor from torquing so badly. Its like you put in hasports and take out the tq mts and you're left in worse shape (performance wise) then you were before....while that might not be quite true, its pretty close.
highroller54
Jan 20, 2010 02:02 PM
D16SohcVtec
Aug 12, 2008 08:03 AM
NAmodified
Oct 16, 2007 08:35 AM
Tire Monkey
May 2, 2004 05:23 PM
rondigs
Jul 21, 2003 06:26 PM
