b16 vaccum lines?
I was looking at this picture and I understand most of it but one of them says run it to the intake and I thought your soppuse to run the one off the valve cover to the intake and also does it matter what map you use the one off the car or engine ive been told before just forgot
alright thanks tell me is this going to work with vaccum lines.....the one that says run to intake..I just ran it to here... I just want to make sure its going to idle right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxpwr1 »</TD></TR><TR><TD CLASS="quote">alright thanks tell me is this going to work with vaccum lines.....the one that says run to intake..I just ran it to here... I just want to make sure its going to idle right
at the nipple under your thumb, the line runs to the purge cannister - most people just remove the entire dashpot on the front of the throttle body
this is the factory B16A vacuum diagram:
</TD></TR></TABLE>at the nipple under your thumb, the line runs to the purge cannister - most people just remove the entire dashpot on the front of the throttle body
yea I know that..I took it out becuase it was in the way...I was showing the hose that runs from the cruise control to the t.....I was wondering if it would idle right...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxpwr1 »</TD></TR><TR><TD CLASS="quote">yea I know that..I took it out becuase it was in the way...I was showing the hose that runs from the cruise control to the t.....I was wondering if it would idle right...</TD></TR></TABLE>
anyone?
anyone?
anyone?</TD></TR></TABLE>
you donk need to hook that pod up.... if that pod gets dirrect vaccume then it WILL make it idle high cuz it pulls the throttle a lil so just plug it all youll be minty
that pod from the factory goes to the intake tube next to the tube for the valve cover but almost all aftermarket intakes dont have the extra nipple...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxpwr1 »</TD></TR><TR><TD CLASS="quote">i got a differnt settup...if I just run a hose to each dash pot...would this work?
Modified by crxpwr1 at 5:29 AM 1/25/2007</TD></TR></TABLE>
he white line drawn from the dash pots....can any one tell me if it will work if I put a vaccum line there
93civiccxhatch
Nov 6, 2004 06:37 PM
