Press fit foged rods??
Old Jan 10, 2007 | 01:35 PM
psegs80's Avatar
Default Press fit foged rods??
I have a Dc2 b18c JDM block...I want to use P73-00 +0.25mm pistons with forged rods but i can't find any that are press fit!
Help
Pat
Old Jan 10, 2007 | 01:49 PM
doood's Avatar
been there done that
Default Re: Press fit foged rods?? (psegs80)
why run stock pistons with forged rods? either upgrade both or dont upgrade at all.
but to answer your question, you'll probably need to have them modified by a machine shop.
Old Jan 10, 2007 | 02:14 PM
psegs80's Avatar
Default Re: Press fit foged rods?? (doood)
Where I want to race my car I have to keep an OEM piston
Is that the onlyway...I was hoping for an i-beam rod that could do press fit!
Pat
Old Jan 10, 2007 | 02:21 PM
doood's Avatar
keep the stock rods then. upgrade to arp rod bolts if you must.
Old Jan 10, 2007 | 02:44 PM
psegs80's Avatar
I did that in my last Ls vtec because at 8mm the OEM bolts where week and I was spining it to 8500rpm (balanced crank assembly aswell) So I have full confidence that I wouldn't spin a bearing at 9200rpm in the b18c ITR with them...I realy wanted lighter!
pat
Old Jan 10, 2007 | 02:49 PM
doood's Avatar
why are you spinning it that high? what cams are you going to use that make power that high? is this a track car?
Old Jan 10, 2007 | 02:52 PM
Shawn C's Avatar
In The Garage
i had my bone stock US ITR bottom end at 9500 RPM more times than i can remember. no problems. spoon has to run stock parts too, but they trust honda
Old Jan 10, 2007 | 02:54 PM
psegs80's Avatar
Yes it's a track car only. I have a ported type r head with welded quech pads reshaped and balanced CCs with a 5 angle valve job. 64mm TB and ported Type R manifold then out a N1 Spoon header...I'm using Skunk2 PRO1 cams!
Pat
Old Jan 10, 2007 | 02:57 PM
psegs80's Avatar
9500 is a bit high, I beleive that at 9100rpm you reach 2195 fps... spoon B18c's peak arround 8200rpm (don't get me wrong I love spoon, I have a 1.5 dif and a header from them)
I'm expecting to peak arround 8600-8800rpm with the SK2 pro1 cams.
Pat
Old Jan 12, 2007 | 06:37 PM
chris2000's Avatar
Anyone have any more feedback on this??
I also had a race that need to run OEM piston, and i wanted to run the car safely to 9200rpm as well have a lighter rods to reduce rotating assemdly.
all-mtr-teg
Mar 17, 2007 05:49 AM
caster troy si
Sep 20, 2006 03:12 PM
petergriffen
Feb 7, 2006 05:40 PM
94vtecmn
May 30, 2003 10:06 PM
