RSX seats in 96-00 civic question.
Old Jan 10, 2007 | 12:58 PM
ekcivic9's Avatar
Default RSX seats in 96-00 civic question.
hello HT,
before someone goes off on me and tells me to do a search, ive already done plenty. i found a few write ups, but nothing concrete.
i want to buy some rsx seats to replace the ripping cloth seats i have now. through the searches ive come up with these results:
a) seats bolt right in, with the exception of one bolt
b) the seat pans / rails swap out. civic rails can be used on the rsx seats.
then i read how the rsx seats are a single solid frame, so the pan cant be swapped out
c) seats can fit with some homemade brackets with a few holes drilled in them
as you can see, those 3 solutions contradict each other.
is there a fool proof way of doing this, or is it mostly trial and error / fabrication?
thanks
Old Jan 10, 2007 | 01:04 PM
Eran's Avatar
HT White Ops
Pretty sure RSX seats require custom brackets.
Old Jan 10, 2007 | 03:30 PM
ekcivic9's Avatar
can anybody else second that?
Old Jan 12, 2007 | 10:53 AM
Jdmglenn's Avatar
Default Re: (ekcivic9)
i would also like to know. I read a bunch of pages also and found alot of diff ways to do it.
Old Jan 12, 2007 | 12:03 PM
civicex442's Avatar
Default Re: (Jdmglenn)
i wouldnt mind knowing either. rsx seats would look good in my ek
Old Jan 13, 2007 | 05:44 PM
ekcivic9's Avatar
do the seat belt brackets swap out?
Old Jan 17, 2007 | 12:32 PM
spectacle's Avatar
bump cuz i need to know too
Old Jan 21, 2007 | 06:37 AM
black7hatch's Avatar
bump. i want to know also
Old Jan 21, 2007 | 06:53 AM
Felliph3's Avatar
Default Re: (black7hatch)
BUMPTY BUMPDY BUMP
Old Jan 21, 2007 | 07:36 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (Felliph3)
Yes, they do require cuztome brackets. The seat pan is welded to the seat so it's not interchangeable.
However, you can use S2k seats or integra seats.
S2k seats look enough like rsx seats, they sit a little lower too for you tall folks.
Old Feb 9, 2007 | 04:13 PM
EJ8 GSR-T's Avatar
Default Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Yes, they do require cuztome brackets. The seat pan is welded to the seat so it's not interchangeable.
S2k seats look enough like rsx seats, they sit a little lower too for you tall folks.</TD></TR></TABLE>
Yeah but the look pretty weak from behind and when your cars slammed they aint so comfortable to get in and out of...plus a nice pair of cloth RSX seats runs about 1/2 of s2k seats
Old Feb 9, 2007 | 05:17 PM
Cboi's Avatar
i know what you mean i could only afford the driver s2k seat
bbyass
Oct 8, 2009 02:41 AM
thatwhiteguy
Jul 15, 2007 08:26 PM
EvenStar
Oct 24, 2006 09:47 PM
BALLIN H22 EK
Jul 2, 2006 09:34 AM
barefootbilly
Mar 31, 2004 06:39 PM
