successful OBD II motor swaps into OBD I integra?
Old Jan 10, 2007 | 12:42 PM
Marco93EJ's Avatar
Default successful OBD II motor swaps into OBD I integra?
Yes HT, im searching as im typing
i've decided on a 2000 LS motor go to into a 1994 integra. i dont have the engine harness or ecu for either.
question is...what OBD1 parts are essential?
for example:
can i use the OBD2 dizzy and alt...and just get OBD1 parts for the rest?
THANKS HT
Old Jan 10, 2007 | 05:14 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: successful OBD II motor swaps into OBD I integra? (Marco93EJ)
If you had an odb1 harness, you'd need ...
ODB1:
Alternator
Distributor
Injectors
You would Not be able to use any of those if they were obd2 on a obd1 harness,
Only because the plug wires won't match up for the parts.
Old Jan 10, 2007 | 05:42 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: successful OBD II motor swaps into OBD I integra? (CleanLikeJdm)
just get an 00 integra LS engine harness, it plugs right in to the tower harness, no wiring neccessary
Old Jan 11, 2007 | 07:45 AM
dc4teg95's Avatar
Default Re: successful OBD II motor swaps into OBD I integra? (HondaPartsHero)
swap out the obd2 injectors with obd 1 injectors, reuse your obd1 wire harness, buy a 94-95 dizzy or get a dizzy jumper, drop motor in and ride.
TravisBiggie
May 24, 2012 07:13 AM
akteamster
Feb 7, 2006 07:18 AM
253EK
May 20, 2004 10:52 PM
fastlude69
May 28, 2003 05:58 AM
C1V1C
Apr 17, 2002 05:38 PM
