What does it take to Rev 9500k + ?
Old Jan 10, 2007 | 12:13 PM
integranator's Avatar
Default What does it take to Rev 9500k + ?
Hey guys, this is my setup so far:
83mm Sleeved b18b + crank
CP's
Carillo's
Head:
GSR
Supertech Springs + Retainers
What else would I need in order to safely rev above 9.5k?
Old Jan 10, 2007 | 12:34 PM
zexxbo's Avatar
Default Re: What does it take to Rev 9500k + ? (integranator)
id go with valves as well, just to be on the safe side. and if youre really weary then maybe manley locks and ferrea guides. im not sure how high supertech springs and retainers are rated for, but i know that ferrea and indy can rev to about 11k ish
Old Jan 10, 2007 | 12:40 PM
DaveF's Avatar
Default Re: What does it take to Rev 9500k + ? (zeimbo)
a good setup, to even make power past 9500......
Old Jan 10, 2007 | 01:08 PM
rextec's Avatar
Default Re: What does it take to Rev 9500k + ? (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
a good setup, to even make power past 9500......</TD></TR></TABLE>
exactly....
balanced bottom end, and some pretty mean cams to add to the list
Old Jan 10, 2007 | 01:13 PM
Topdawgg's Avatar
would GSR cams in a b16 head with supertech valves, springs and retainers make that?
with a fully built block of course..
84mm GE sleeves
CP pistons
MAnley Rods
Old Jan 10, 2007 | 01:18 PM
komat's Avatar
Default Re: (Topdawgg)
you probably stop making power at 8200 or so depending on the turbo you go with. why do you want to rev it to 9500?
Old Jan 10, 2007 | 02:06 PM
MotorMouth's Avatar
Default Re: (komat)
you should also get a block girdle, thats if you dont already have one. IMO wouldn't spin a b18b to 9500 without one.
Old Jan 10, 2007 | 03:07 PM
ccivic's Avatar
Default Re: (MotorMouth)
What kind of turbo do you plan on running?!
Old Jan 10, 2007 | 05:04 PM
Default Re: (ccivic)
t3/67 H.O. is what I was going to run. I know I'm going to need a large powerband with that turbo, so I wanted to be safe to rev high enough.
Old Jan 10, 2007 | 05:16 PM
cuin9sec
Guest
Posts: n/a
pssshhh...i just run a stock b16 head and rev to 11k
Old Jan 10, 2007 | 06:57 PM
vtec4max's Avatar
your stock b16 reving at 11k is aging very fast
Old Jan 10, 2007 | 07:08 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: What does it take to Rev 9500k + ? (rextec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rextec &raquo;</TD></TR><TR><TD CLASS="quote">
exactly....
balanced bottom end, and some pretty mean cams to add to the list</TD></TR></TABLE>
my peak power was 520 on the last plot that i printed at 9800, rev valvetrain with gsr cams. granted it was a b16, i hope my maz cams are up to the task of 11k he hee.
Old Jan 10, 2007 | 07:28 PM
Garage 808 Hatch's Avatar
Default Re: What does it take to Rev 9500k + ? (boostedcivicsir)
yup, my peak of 435 on a b16 was at 9900, but thats where i let off, graph was still climbing, rev valvesprings and retainers, stock valves. t3/62-1 .83 ex
Old Jan 11, 2007 | 03:47 AM
DaveF's Avatar
Default Re: What does it take to Rev 9500k + ? (Garage 808 Hatch)
our racecar stoped making power @ 9250
42R
alcohol/38-40 psi. boost.
stock gsr cams/no adjustements.
Old Jan 11, 2007 | 04:39 AM
Synapse Motorsport's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch &raquo;</TD></TR><TR><TD CLASS="quote">yup, my peak of 435 on a b16 was at 9900, but thats where i let off, graph was still climbing, rev valvesprings and retainers, stock valves. t3/62-1 .83 ex </TD></TR></TABLE>
The only way it made power till 9900 was because you had massive boost creep, I'd like to see the dyno graph of that.
Old Jan 11, 2007 | 05:30 AM
Default Re: What does it take to Rev 9500k + ? (Synapse Motorsport)
I guess the point of this post, is not to increase the power that the motor is seeing, but to make sure that the motor would be able to see the revrange that I wanted. Unfortunately not many of you have actually answered the question, just talking about where your power fell off, which doesn't really help me. Do you think that the Block girdle would be a good investment? The block is at the machine shop right now, so adding the main girdle now would be the best time to. Also, do you think the supertech springs/retainers will handle the occasional 9.5k pull?
Old Jan 11, 2007 | 06:01 AM
DaveF's Avatar
id recomend block girdle + main studs(z10 girdle/aebs studs)
balance and polish the crank
definitly upgrade the springs and retainers. also a cam with specs "larger" than gsr will help you make a more useable powerband.
also, a good harmonic balancer (ATI superdamper) will help keep your oil pump in one piece
Old Jan 11, 2007 | 04:12 PM
sorry its in mph, the rpm pickup skips on my car.
this is 3rd gear on stock sized tires.
and its not myh best pull,just the one i have scanned
Old Jan 11, 2007 | 05:14 PM
cuin9sec
Guest
Posts: n/a
Default Re: (vtec_avenue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_avenue &raquo;</TD></TR><TR><TD CLASS="quote">your stock b16 reving at 11k is aging very fast</TD></TR></TABLE>
lol...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">our racecar stoped making power @ 9250
42R
stock gsr cams/no adjustements. </TD></TR></TABLE>
yes BUT your race car is SLOW...
JK man...hows your car coming along?
89efhatchy
Apr 3, 2014 12:42 PM
89efhatchy
Mar 14, 2014 06:32 PM
civicegsick
Dec 30, 2007 11:54 PM
Fatty_1775
Aug 9, 2006 07:42 PM
MI4eg
Sep 27, 2003 09:27 PM
