h22a firing issue
Old Jan 10, 2007 | 11:39 AM
slowem1si's Avatar
Default h22a firing issue
hey everyone, I have a 95 h22a in my 96 ek hatch. The motor has been in the car and running great for about 4000 miles. The other day i was driving the car and it lost power, feels as if its running on 3 cylinders, or how it would run if you had a bad spark plug or wire. i compression tested the motor and it has 240 psi across the board. So im pretty sure there is no internal damage. I have replaced the spark plugs and plug wires. I pulled the fuel rail and cleaned the injectors and they seem to be pulsing correctly when they get 12 volts. I just recently put a brand new distributer on so i beleive that is good, and i checked and im getting spark to each plug. I am really stumped on why the motor is running poorly if anyone could give me some suggestions that would be great. Thanks Garrett
Old Jan 10, 2007 | 11:56 AM
MidwestSiR's Avatar
i'd try another dizzy.. Is it an OEM one you're running?
Old Jan 10, 2007 | 12:56 PM
slowem1si's Avatar
Default Re: (MidwestSiR)
n<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestSiR &raquo;</TD></TR><TR><TD CLASS="quote">i'd try another dizzy.. Is it an OEM one you're running? </TD></TR></TABLE>
no its from like distributor king or something. but that one was on the car from when we finished the swap and its run fine for like 4000 miles?
Old Jan 10, 2007 | 01:44 PM
slowem1si's Avatar
Default Re: (slowem1si)
i have another one so im going to give that a try i hope it works
Old Jan 12, 2007 | 06:43 PM
slowem1si's Avatar
PROBLEM SOLVED: Injector Resistor box went bad, the output wire for the first cylinder was outputting 0.0volts. I dropped in a new 12volt line with a 10 watt 10 ohm injector and it runs like a champ.
Metal Head
Apr 17, 2009 07:50 AM
colocho19
Mar 16, 2009 06:41 PM
ilandhopr
Sep 21, 2007 05:35 AM
slowem1si
Jan 16, 2007 08:07 AM
