h22a firing issue
h22a firing issue
hey everyone, I have a 95 h22a in my 96 ek hatch. The motor has been in the car and running great for about 4000 miles. The other day i was driving the car and it lost power, feels as if its running on 3 cylinders, or how it would run if you had a bad spark plug or wire. i compression tested the motor and it has 240 psi across the board. So im pretty sure there is no internal damage. I have replaced the spark plugs and plug wires. I pulled the fuel rail and cleaned the injectors and they seem to be pulsing correctly when they get 12 volts. I just recently put a brand new distributer on so i beleive that is good, and i checked and im getting spark to each plug. I am really stumped on why the motor is running poorly if anyone could give me some suggestions that would be great. Thanks Garrett
Re: (MidwestSiR)
n<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestSiR »</TD></TR><TR><TD CLASS="quote">i'd try another dizzy.. Is it an OEM one you're running? </TD></TR></TABLE>
no its from like distributor king or something. but that one was on the car from when we finished the swap and its run fine for like 4000 miles?
Re: (slowem1si)
PROBLEM SOLVED: Injector Resistor box went bad, the output wire for the first cylinder was outputting 0.0volts. I dropped in a new 12volt line with a 10 watt 10 ohm injector and it runs like a champ.
