Weird sound? (with video)
Old Jan 10, 2007 | 11:32 AM
zach1288's Avatar
Default Weird sound? (with video)
I have not noticed this sound before but today when my brother got into my car he said "your car is making a loud noise" but i could not hear it from inside the car. I think its the bumper making the noise since i have stiff motor mounts and it vibrates pretty hard, when i press on the bumper the sound goes away, also it was about 30 or less degrees out today so im not sure if that had something to do with it. Let me know what you think, thanks.
http://s29.photobucket.com/alb...2.flv
Old Jan 10, 2007 | 11:34 AM
turboDeznutz's Avatar
Default Re: Weird sound? (zach1288)
Old Jan 10, 2007 | 11:35 AM
gezzuzz's Avatar
check you belts first.. might have a peice flaping around
Old Jan 10, 2007 | 11:40 AM
zach1288's Avatar
Default Re: Weird sound? (gezzuzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz &raquo;</TD></TR><TR><TD CLASS="quote">check you belts first.. might have a peice flaping around</TD></TR></TABLE>
Why would the sound go away when i touch the bumper then?
Modified by zach1288 at 4:00 PM 1/10/2007
Old Jan 10, 2007 | 11:51 AM
civhatch90's Avatar
it seems like something is loose and vibrating
Old Jan 10, 2007 | 12:00 PM
zach1288's Avatar
Default Re: (civhatch90)
I played with the bumper alittle and got it to stop, so something is definitely loose but i will tighten everthing up this weekend when i install my new axles
Modified by zach1288 at 4:11 PM 1/10/2007
Old Jan 10, 2007 | 12:11 PM
bart2546's Avatar
Default Re: (zach1288)
probably some kind of plastic shielding that has one of those snappy button things broken/missing/out. Should be pretty easy to locate once you look under it.
Old Jan 10, 2007 | 01:05 PM
blk_EK's Avatar
Default Re: (bart2546)
just take ur bumper off and turn the car on.
Take at the most 5 minutes.
If it stops rattling put the bumper back on.
Prolly just a loose bolt or just something out of the ordinary
Old Jan 10, 2007 | 02:09 PM
ridin98civic's Avatar
the bracket under the headlight? seems like when you put pressure on the bumper it would in turn put pressure on that bracket and stop it
DumbleDore!
Oct 25, 2018 06:35 AM
es_squared
Mar 15, 2007 06:48 PM
rizen
Sep 30, 2003 01:56 PM
Boostless97Lude
Mar 9, 2003 04:49 PM
Halive
Jan 3, 2002 03:49 AM
