Opinions on my future sound system....
Old Jan 10, 2007 | 05:21 AM
B18Sleeper's Avatar
Default Opinions on my future sound system....
Ok I dont see much talk on here about JL W7's and i was wondering what this system would be like....Right now all i have is a headunit which is a Jensen 7" Motorized In dash TV, but the system i want is listed below and i want something that is clear and crisp and has some bass but nothing outrageous. so please feel free to give any suggestions
JL 10" W7
JL 500.1 Amp
Knukonceptz Wiring
JL 400.4 Amp for components
Need components have no idea here
Thanks
Old Jan 10, 2007 | 06:14 AM
RICO_'s Avatar
NO MERCY!
Default Re: Opinions on my future sound system.... (B18Sleeper)
10W7 is outrageous bass and will most likely not please you. It is designed for raw SPL (Sound pressure level).
Go with a single 12W6 or even a 12W3V3 would be good to and save some weight. The amp is good. The 500/1 is a badass amp which will work on any of those subs. But if you want bass quality go for the W6 series rather than the W7 series. Make sure you use 4 gauge wire on the amp though. All the JL slash series require 4 gauge minimum.
Old Jan 10, 2007 | 06:56 AM
94_DC4's Avatar
What car is all this equipment going into?
Old Jan 10, 2007 | 07:43 AM
fcm's Avatar
fcm
Old Fart
The 10W7 and 500/1 work very well together, and if installed in a proper box will give you not only lots of SPL when you want but will give you clean accurate sub bass response... http://mobile.jlaudio.com/prod..._id=5
I would definitely look at the JL Audio cabinets for the sub... http://mobile.jlaudio.com/prod...id=12 or build to spec... http://mobile.jlaudio.com/prod..._id=5 94
Old Jan 10, 2007 | 10:00 AM
RICO_'s Avatar
NO MERCY!
Default Re: Opinions on my future sound system.... (fcm)
As for components go for FOCAL. They are handmade and have some of the best clarity you will ever hear.
Old Jan 10, 2007 | 10:33 AM
B18Sleeper's Avatar
this is going in a 00 civic si, i mean this is just a idea i aint set on it yet i'm just tryin to figure out what i need or what would work best. so with that in mind what should i do ? and what focal components should i go with do they have only one series or what? thanks
Old Jan 10, 2007 | 12:59 PM
LSRracing95's Avatar
id ditch that jensen unit..
Old Jan 10, 2007 | 01:04 PM
B18Sleeper's Avatar
Default Re: Opinions on my future sound system.... (LSRracing95)
and get what? i still want a in dash tv.
Old Jan 11, 2007 | 03:14 AM
RICO_'s Avatar
NO MERCY!
Not sure if a double din will fit on a 00 Si, but if you want a good flip out get a Kenwood Excelon. They're a little pricey but worth every penny.
Old Jan 11, 2007 | 05:26 AM
B18Sleeper's Avatar
Default Re: Opinions on my future sound system.... (RICO_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RICO_ &raquo;</TD></TR><TR><TD CLASS="quote">Not sure if a double din will fit on a 00 Si, but if you want a good flip out get a Kenwood Excelon. They're a little pricey but worth every penny. </TD></TR></TABLE>
i may i dont know, but is there any others? for right now i am keeping my jensen cause it serves the use of what i want lol....when i get my system money aint a big deal cause as u can tell with w7's they are pricey so i will spend whatever money i need to so i get a good setup that wont just bang my ears out but be crisp and loud thanks
Old Jan 11, 2007 | 04:15 PM
RICO_'s Avatar
NO MERCY!
There's lots of others to choose from. You can go with an Alpine IVAD310 flip out, Pioneer also makes a couple different flip outs as does Eclipse, although I think the eclipse ones have built-in Navigation and are really pricey.
Old Jan 12, 2007 | 08:49 AM
B18Sleeper's Avatar
ok thanks for the tips on that. appreciate it.
Old Jan 14, 2007 | 11:38 PM
B18Sleeper's Avatar
where is the best site to get focals from ?
Old Jan 15, 2007 | 05:18 AM
RICO_'s Avatar
NO MERCY!
http://www.focal-america.com
http://www.woofersetc.com
Old Jan 15, 2007 | 06:30 AM
perseverance's Avatar
2din fits in a 00si. u can either use the kit or just use the isomount brackets that are used with the factory radio instead of the plastic single din dash kit.might need a trim ring tho. it's what i did when i installed a eclipse 2din into my friends car. it's clean too.
Old Jan 15, 2007 | 11:58 AM
B18Sleeper's Avatar
Default Re: (perseverance)
thanks for the site and thanks for that info, but for right now i will live with my jensen until i deside on which system to go with. thanks
dth0ng69
Audio / Security / Video
Jul 25, 2008 10:46 AM
Stiffler
Feb 16, 2004 02:13 PM
MooreBoost
22
Nov 26, 2003 08:32 AM
GroundZer0 336
Aug 21, 2003 09:49 AM
el_chapu-bling
Dec 26, 2001 09:23 AM
