Need help on ignition coil
Old Jan 10, 2007 | 01:00 AM
Halfbreed Soldier's Avatar
Default Need help on ignition coil
I have an MSD SCI (Sport Compact Ignition) ignition amplifier for my 95 Civic. What is the best choice coil to get with it? Msd Blaster, Blaster2, etc......... any help is appreciated.
Old Jan 10, 2007 | 05:03 AM
B18C_EJ8's Avatar
Stock. Unless you're running high boost or significant engine mods, the MSD will do nothing for you and can cause problems. I'm actually pulling my 6AL and Blaster coil due to problems at high RPM on my built GSR engine.
Old Jan 10, 2007 | 12:30 PM
Default Re: (B18C_EJ8)
It is a built up motor besides all the basic bolt-ons, I'm using high compression pistons (11.0:1 as oppose to the stock 9.0:1), an upgraded valvtrain, and a stock cam. If the ignition amplifier still wouldn't really make a difference with these mods, please let me know so I can just go ahead and sell it. I appreciate the help.
Old Jan 10, 2007 | 12:40 PM
B18C_EJ8's Avatar
As stated above:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I'm actually pulling my 6AL and Blaster coil due to problems at high RPM on my built GSR engine. </TD></TR></TABLE>
I'm also running high compression (Over 12:1) and Skunk2 Stage 2 cams...
Old Jan 11, 2007 | 10:43 PM
Ok. Thanks for the help.
JDM CALI STYL3
13
Aug 19, 2007 09:22 AM
K-Spec
Jan 8, 2005 03:48 PM
slooogsr
Jul 5, 2003 08:55 PM
SIK IN DA HED
Jul 31, 2001 01:25 PM
