which tranny fluid to use? GM FM syncromesh? Redline? Amsoil? Motul?
Old Jan 9, 2007 | 08:18 PM
BB1_VTEC's Avatar
Default which tranny fluid to use? GM FM syncromesh? Redline? Amsoil? Motul?
i have a bit of a high rpm grinding issue for the past few months.. its like whenever i redline it wont go into gear when i shift. but whenever i gun it to 6500 and shift i can shift perfectly. im leaning towards syncros and im running honda mtf in it.. ive heard alot about these products and how it works wonders but im feelin kinda iffy b/c ive read about these here in civic's and integra forums.. i want to hear from the prelude folks about what you guys recommend.
and ps dont flame I SEARCHED
Old Jan 9, 2007 | 08:57 PM
roller3804's Avatar
dont use anything but MTF. All those other fluids merely mask the hard fact that ur tranny is in need of a rebuild. Take it easy on your tranny.Stick with MTF. Rebuild your tranny.
Here is a great company for rebuilds.
http://www.gear-speed.com
Old Jan 9, 2007 | 08:59 PM
thegeorge613's Avatar
Default Re: which tranny fluid to use? GM FM syncromesh? Redline? Amsoil? Motul? (BB1_VTEC)
Honda revised their MTF formula. After adding the new MTF, my shifting really improved from before (when using old MTF).
Old Jan 9, 2007 | 09:01 PM
Rosko's Avatar
Default Re: which tranny fluid to use? GM FM syncromesh? Redline? Amsoil? Motul? (thegeorge613)
FWIW I've used GM synchromesh and it works just fine, but its not tranny rebuild in a bottle...
Old Jan 9, 2007 | 09:51 PM
BB1_VTEC's Avatar
Default Re: which tranny fluid to use? GM FM syncromesh? Redline? Amsoil? Motul? (Rosko)
sounds like you guys got a point... i have another question... is it better to do a full tranny rebuild or pick up another jdm transmission and swap it over? comparing prices now, i could spend about 1000 on a tranny rebuild and call it quits or i can just pick a jdm one up for 300 and swap it in myself.
Old Jan 10, 2007 | 06:30 AM
smo0th's Avatar
I just changed my tranny fluid 3 weeks ago. I used MTF and it got rid of my 5th gear grind (for now ) It works great though, the whole gearbox feels better.
Old Jan 10, 2007 | 07:47 AM
roller3804's Avatar
Where do you think you can get a JDM tranny for 300 ? I have only seen them for 550 at the lowest.
I was just saying if ur gonna rebuild your tranny you might as well do it really well.
Old Jan 10, 2007 | 08:30 AM
hondatech739's Avatar
hey,about using the aftermarket trans oils,for goodness sake man,don't do it.that stuff can really tear one up.i have seen many a tuner regret changing to redline fluid.I think it is just too thin for hondas trannys.so far ive replaced trannys in 3 different gsr integras and one civic si for guys who said they didn't hit it hard,they just switched to redline.
as far as rebuild,if you're handy and have the time,it only takes a day once you get the parts.original honda parts are expensive,but when you take care of them they last.
Old Feb 1, 2007 | 10:20 AM
MachAF's Avatar
i've been using GM syncromesh for 30k+ miles now. Cured my 3rd gear grind at high rpms. It works wonders.
Old Feb 1, 2007 | 10:31 AM
InvaderTrax's Avatar
Have any of you tried GM synchromesh in a brand new S2000? It's amazing. The friction modifier doesn't cover up grinds, it allows everything to move smoother and easier. If you put it in from the beginning it'll decrease transmission parts wear
Old Feb 1, 2007 | 11:24 AM
ninja 6's Avatar
Default Re: (InvaderTrax)
hey does your cousin still have the white si and the eclipse gst?
-Championship-
Jun 29, 2006 12:37 AM
mr. goodwrench
Jan 18, 2006 01:59 AM
jdmjeff
May 17, 2005 07:46 PM
HuskerHybrid
May 20, 2003 09:06 AM
ill phil
15
Sep 4, 2002 10:37 PM
