Oil line?
Old Jan 9, 2007 | 07:34 PM
psikotc's Avatar
Default Oil line?
bought a new turbo manifold (to replace my continualy cracking ss autocrap 1) the only way that my oil line will reach my turbo now is if the line runs over the top of the engine. should i get a longer line that will run around the side of the engine or is that ok?
Old Jan 9, 2007 | 07:36 PM
siblues's Avatar
Default Re: Oil line? (psikotc)
If its the feed line it should be ok.Either I think will work as long as the line isnt extremely long?
Old Jan 9, 2007 | 07:40 PM
psikotc's Avatar
Default Re: Oil line? (siblues)
line is 3', was fine with the old manifold i had but with the new 1 the turbo is mounted the opposite direction so the line wont reach as it did before.
Old Jan 9, 2007 | 07:43 PM
ccivic's Avatar
I run mine 'through' the gap on the valve cover where the valve cover extends to cover the cam gears.. never had any issues.
Old Jan 9, 2007 | 08:01 PM
stealthmode62's Avatar
Default Re: Oil line? (ccivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic &raquo;</TD></TR><TR><TD CLASS="quote">I run mine 'through' the gap on the valve cover where the valve cover extends to cover the cam gears.. never had any issues.</TD></TR></TABLE>
My old 3ft lines were almost always ran in this fashion. Just be sure to secure the line so it isn't moving around things you don't want a hole in.
Old Jan 9, 2007 | 08:41 PM
psikotc's Avatar
Default Re: Oil line? (stealthmode62)
i can't run it "through" the valve cover, it won't reach that way. it runs diagonaly across the valve cover, do you think it will be ok like that? or do i need to figure out some type of sleeve for where it contacts the valve cover?
Old Jan 9, 2007 | 11:08 PM
95dc2teg's Avatar
i have might running right over the top of the engine from the back of the block to the turbo. Absolutely no problems so you should be fine.
Old Jan 10, 2007 | 03:40 AM
psikotc's Avatar
Default Re: Oil line? (95dc2teg)
thanks for the input guys!
WAUKEENEM1
Nov 5, 2013 01:02 PM
SkyliteCustomz
Feb 5, 2010 12:37 AM
P.S.I Garage
Sep 1, 2008 11:59 PM
accord99power
May 21, 2008 09:45 AM
glagola1
Jan 7, 2002 12:28 AM
