oil feed and return line....T3 super 60
i got one( used) and just trying to see what is the return and feed line on the turbocharger. also i think this one is water also?? not sure though. could you T3 guys tell me what the 2 flange looking like things between the compressor and exhaust is?? thanks
yes that t3 is water and oil ccooled....water-u dont have to hook up...oil-obviously yes...
but u can if u want, as for the oil feed line and return line, the feed is 1/8 npt so any 1/8 fitting will work...as far as the return...that should be -10an, as big, better flow.....u need a universal t3 oil return flange, and a 5 bolt flangee to cover uup the stock wastegate acutator...the flapper disc.....(unless u run the stock internal,but i use thhe tial so i needed thhat cover flange)
u can get all these fittings from earls or summit.....the flanges at road race engineering or tuurbonetics....ill try to post a pic of mine......
Poop111444
Jul 8, 2003 06:08 AM
