Deleting heat & A/C (92-95), best way to deal with coolant heater hoses?
Old Jan 9, 2007 | 02:35 PM
Fuster_Cluck's Avatar
Default Deleting heat & A/C (92-95), best way to deal with coolant heater hoses?
I really don't want to spend any money on this since I am pulling the motor shortly for a swap. I am deleting the entire heat/ A/C system. Is there a Pep Boys / Auto Zone hose that will join the two?
Thanks for any help!!
Old Jan 9, 2007 | 02:38 PM
gezzuzz's Avatar
Default Re: Deleting heat & A/C (92-95), best way to deal with coolant heater hoses? (Hybrid93Hatch)
block them off!!! or connect them.. blocking off is cleaner
Old Jan 9, 2007 | 02:40 PM
Default Re: Deleting heat & A/C (gezzuzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz &raquo;</TD></TR><TR><TD CLASS="quote">block them off!!! or connect them.. blocking off is cleaner</TD></TR></TABLE>
With caps? Where can I get them?
Can I connect the 2 using the existing hoses?
Thanks
Old Jan 9, 2007 | 02:45 PM
Eran's Avatar
HT White Ops
Run a hose from where the #4 hose connects to the block and where the #6 hose connects to the block.
Old Jan 9, 2007 | 02:50 PM
gezzuzz's Avatar
Default Re: (Eran)
or go to autozone they sell the cap that you can push over the ends and clamp down...
Old Jan 9, 2007 | 02:57 PM
Eran's Avatar
HT White Ops
Default Re: (gezzuzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz &raquo;</TD></TR><TR><TD CLASS="quote">or go to autozone they sell the cap that you can push over the ends and clamp down... </TD></TR></TABLE>
I'd be a little more nervous about that ....
Old Jan 9, 2007 | 03:13 PM
gezzuzz's Avatar
Default Re: (Eran)
the only problem with putting a hose between the pipes comming out the motor is that hot radiator fuild will flow thru it when ever your car is running.. hoses will wear out.. but than agian so could the caps.. the smartest thing to do would be to weld the holes shut..
Old Jan 9, 2007 | 03:15 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz &raquo;</TD></TR><TR><TD CLASS="quote">the only problem with putting a hose between the pipes comming out the motor is that hot radiator fuild will flow thru it when ever your car is running.. hoses will wear out.. but than agian so could the caps.. the smartest thing to do would be to weld the holes shut.. </TD></TR></TABLE>
Is the "cap" metal or plastic? Be cause a banded silicone radiator hose is probably less likely to corode or melt.
Old Jan 9, 2007 | 03:59 PM
Default Re: (JJSpecTuning)
Partsamerica.com = Advance Auto Parts? If so, didn't know that.
They're only $3. May have to get a set. I'm going to try to rig the OEM hoses first. I won't be driving the car anymore. Just need to crank it to move back in the garage / make sure everything is good after I do the wire tuck
Old Jan 9, 2007 | 04:01 PM
koa's Avatar
koa
Default Re: (Hybrid93Hatch)
find two extra bolts that are slightly bigger in diameter than the hose and thread them into the hoses. Works fine and wont just fall out like the caps do.
Old Jan 9, 2007 | 04:07 PM
gezzuzz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJSpecTuning &raquo;</TD></TR><TR><TD CLASS="quote">i think i found the caps
http://www.partsamerica.com/Pr...02252</TD></TR></TABLE>
damn i was looking all over for i picture for him..
you have to clamp them down good but then you are set..
fhukingviet
Mar 12, 2009 10:44 AM
Mikey3000
Jun 23, 2008 04:31 AM
jeezyskillz
Nov 26, 2006 11:40 PM
Tippyman
Nov 23, 2006 06:57 PM
275Performance
Jun 7, 2003 08:45 AM
