just looking for a little input.......
Old Jan 9, 2007 | 11:24 AM
killerB16A's Avatar
Default just looking for a little input.......
what is the best possible setup for ls/vtec? one of my friends told me that a b16 head is the best way to go. can i just put a b16 head on a stock ls bottom? i know there is more to it than just throwing a head on a block.
thanx for the input,
jason
Old Jan 9, 2007 | 12:42 PM
doood's Avatar
been there done that
Default Re: just looking for a little input....... (killerB16A)
https://honda-tech.com/zerothread/1676914
https://honda-tech.com/zerothread/1812388
you know, honda-tech is comprised of more than just the civic forum
Old Jan 9, 2007 | 12:47 PM
jdmitr's Avatar
As said above you should search, but yes that is a good combo...a quality ported b16 head would be even better!
Old Jan 10, 2007 | 01:03 AM
killerB16A's Avatar
Default Re: just looking for a little input....... (jdmitr)
i have a b16a2 with ctr pistons, toda cams port and pollish and i cant remember what kind of valves springs and retainers i have. but i was thinking to use the complete head and the ctr pistons. can i use the ctr pistons?
Old Jan 10, 2007 | 11:24 AM
doood's Avatar
Default Re: just looking for a little input....... (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerB16A &raquo;</TD></TR><TR><TD CLASS="quote">i have a b16a2 with ctr pistons, toda cams port and pollish and i cant remember what kind of valves springs and retainers i have. but i was thinking to use the complete head and the ctr pistons. can i use the ctr pistons?</TD></TR></TABLE>
can you read?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread/1676914
you know, honda-tech is comprised of more than just the civic forum</TD></TR></TABLE>
Old Jan 10, 2007 | 11:50 AM
killerB16A's Avatar
it doesnt say anything about ctr pistons. are they the same as itr? but it was a very good write up and i will be using it.
Old Jan 10, 2007 | 01:06 PM
doood's Avatar
ctr pistons are heavy and have a huge dome. your compression is going to be very high with them in a b18 block.
Old Jan 10, 2007 | 04:58 PM
killerB16A's Avatar
so should i use them? any idea where about the compression will be at?
Old Jan 10, 2007 | 05:00 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerB16A &raquo;</TD></TR><TR><TD CLASS="quote">so should i use them? any idea where about the compression will be at?</TD></TR></TABLE>
Yeah.
Here.
Old Jan 10, 2007 | 05:21 PM
doood's Avatar
you shouldnt use them. p30's or jdm p73's give a much more reasonable cr and have a much smaller dome.
you can make more power and be safer with less cr and running more ignition timing. rather than having to pull lots of timing with a high cr.
Old Jan 10, 2007 | 11:42 PM
killerB16A's Avatar
thank you very much that was great info!!!!!!!!
chinpak
Mar 15, 2007 06:20 PM
nickel168
Sep 14, 2006 12:24 AM
lowkeyciv
Apr 25, 2003 03:57 PM
