ECU CODE "91". Fuel Tank Pressure Sensor. Low Input.
Old Jan 9, 2007 | 11:04 AM
thoughtbox's Avatar
Default ECU CODE "91". Fuel Tank Pressure Sensor. Low Input.
I'm stuck. Anybody have any ideas. I have swapped the gas cap, the fuel pump and the fuel filter.
Old Jan 9, 2007 | 02:12 PM
01usjdmr's Avatar
Why would you replace those for that code? Most likely a bad ftp sensor (I have replaced alot of them). Emissions codes can be a pain to diag.
Old Jan 9, 2007 | 03:54 PM
thoughtbox's Avatar
Default Re: (01usjdmr)
Long story, but I had all those parts spare(except the fuel filter, which I thought I should replace anyway). But I figure low tank pressure, could be some of those things.
Is there a way to test the FTP sensor, with a ohm/volt meter or something?
thanks
mugenboi
May 24, 2007 11:49 AM
esoterEK..
Jun 11, 2004 07:06 AM
JDMJONES
Apr 14, 2004 03:38 PM
KiLLa CaM 06
11
Feb 15, 2003 10:04 AM
DR. ON POINT
Dec 27, 2002 02:32 PM
