Missing piece
Old Jan 5, 2007 | 12:05 PM
andyt's Avatar
Default Missing piece
The "bracket" that goes on the top of part 6/7 is missing on my car.
Now, I never took that section of the car apart until a few days ago, so I know that I didn't lose it.
I suspect the body shop forgot to put it on. Also havent checked the other side yet to see if its missing there too.
Did the 97s/98s have this piece for sure, or was it added for the 00/01 models?
How important is it?
Old Jan 5, 2007 | 12:11 PM
EG6-DC2's Avatar
Default Re: Missing piece (andyt)
Are you talking about the part that bolts it to the shock tower?
Old Jan 5, 2007 | 12:12 PM
walker111's Avatar
Default Re: Missing piece (EG6-DC2)
I hope you have that part! Take a pic of what you have...
Old Jan 5, 2007 | 12:17 PM
EG6-DC2's Avatar
Default Re: Missing piece (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">I hope you have that part! Take a pic of what you have...</TD></TR></TABLE>
Thats what I'm saying....If it wasn't there, it would just fall out!
Old Jan 5, 2007 | 12:18 PM
NIKE SB'd's Avatar
Only way you wouldn't have that piece is if you used a cheesy camber kit.
Old Jan 5, 2007 | 12:21 PM
walker111's Avatar
Default Re: (NIKE SB'd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NIKE SB’d &raquo;</TD></TR><TR><TD CLASS="quote">Only way you wouldn't have that piece is if you used a cheesy camber kit. </TD></TR></TABLE>
I think Ingalls makes a kit like that.
Old Jan 5, 2007 | 12:26 PM
andyt's Avatar
Default Re: (walker111)
I'm talking about the thin little piece of metal that slides over the 2 bolts, not the assembly itself
You can see it in the picture.
Old Jan 5, 2007 | 12:28 PM
walker111's Avatar
Default Re: (andyt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andyt &raquo;</TD></TR><TR><TD CLASS="quote">I'm talking about the thin little piece of metal that slides over the 2 bolts, not the assembly itself </TD></TR></TABLE>
They are one with the bolts IIRC.
Old Jan 5, 2007 | 12:29 PM
EG6-DC2's Avatar
Yeah, I'm pretty sure its one piece.
Old Jan 5, 2007 | 12:30 PM
andyt's Avatar
Negative..at least on mine.
On my 2000 its a seperate piece that slides off the top of the bolts.
On the 98 its just not there.
Old Jan 5, 2007 | 12:34 PM
walker111's Avatar
Default Re: (andyt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andyt &raquo;</TD></TR><TR><TD CLASS="quote">Negative..at least on mine.
hrmm, all these random questions today
You'll have to wait until I get home to check my 00.
Old Jan 5, 2007 | 12:35 PM
EG6-DC2's Avatar
Default Re: (andyt)
Thats weird. I'm pretty sure when I did the 5-lug on my old h/b, I woudl grab it by the bracket and it never came apart.
Old Jan 5, 2007 | 12:36 PM
EG6-DC2's Avatar
Default Re: (EG6-DC2)
Maybe I will look at mine sometime this weekend and see if mine has it.
Old Jan 5, 2007 | 12:37 PM
andyt's Avatar
Yeah, I've got a million things going through my head right now......
Part of the reason I'm asking is that I could not for the life of me get the bolts any tighter when I mounted that assembly back to the shock tower, and theres a teeny tiny little bit of space underneath where I suspect that bracket should have been.
Old Jan 5, 2007 | 12:39 PM
EG6-DC2's Avatar
Default Re: (andyt)
What was it taken out for anyways?
Old Jan 5, 2007 | 12:42 PM
RTW DC2R's Avatar
IIRC I had to remove that whole bracket thing in order to install an ingalls kit on my old Del Sol. I dont remember if I had it on my R when I installed my Junk2 UCAs on my R.
Old Jan 5, 2007 | 12:43 PM
walker111's Avatar
Default Re: (RTW DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">IIRC I had to remove that whole bracket thing in order to install an ingalls kit on my old Del Sol. I dont remember if I had it on my R when I installed my Junk2 UCAs on my R. </TD></TR></TABLE>
IIRC its on the skunk2's
andyt's Avatar
My driveshaft on my 98 had a torn boot and was making noises so I wanted to swap the driveshaft from the 00, however we could not get the driveshaft on the 98 out of the hub.
I ended up swapping the whole hub and assembly over.
A friend with a 30 ton press just got the axle out this afternoon, and it strained the press lol.
That fugger was jammed up in there!
Old Jan 5, 2007 | 12:44 PM
GO-FIGHT-KILL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2ARG &raquo;</TD></TR><TR><TD CLASS="quote">IIRC I had to remove that whole bracket thing in order to install an ingalls kit on my old Del Sol. I dont remember if I had it on my R when I installed my Junk2 UCAs on my R. </TD></TR></TABLE>
^ Are Skunk2 Camber Kits bad? I just picked up the fronts, planning on installing them this weekend... Should I not?
EG6-DC2's Avatar
Default Re: (andyt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andyt &raquo;</TD></TR><TR><TD CLASS="quote">My driveshaft on my 98 had a torn boot and was making noises so I wanted to swap the driveshaft from the 00, however we could not get the driveshaft on the 98 out of the hub.
That fugger was jammed up in there!</TD></TR></TABLE>
Damn, thats some serious pressure!
Old Jan 5, 2007 | 12:45 PM
RTW DC2R's Avatar
supposed to l00b dat chit
walker111's Avatar
Default Re: (andyt)
I used a sledge hammer to get mine out, then I had to dremel off the end so it would fit thru the hub
Old Jan 5, 2007 | 12:46 PM
RTW DC2R's Avatar
Default Re: (GO-FIGHT-KILL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">
^ Are Skunk2 Camber Kits bad? I just picked up the fronts, planning on installing them this weekend... Should I not?</TD></TR></TABLE>
never had a problem with mine, and I have the old version. I took the safety precautions though (longer bolts, star washers, sanded down the painted surface). I dont think the newer style has that problem.
Old Jan 5, 2007 | 12:47 PM
RTW DC2R's Avatar
I used a sledge hammer to get mine out, then I had to dremel off the end so it would fit thru the hub </TD></TR></TABLE>
I am the master at doing that with my lower ball joints
thats why Im thinkin about trying those fancy FLCAs...
^ What problem did the old ones have?
