90 integra cant pass "NOX" Emissions...
Old Jan 9, 2007 | 10:43 AM
Elbowpunk's Avatar
Default 90 integra cant pass "NOX" Emissions...
i have a new Cat on there ..... passing everything else but the NOX over by .12 points.... any idea how i can pass !! ??
thanks in advance
Old Jan 9, 2007 | 11:33 AM
jay_cue's Avatar
Default Re: 90 integra cant pass "NOX" Emissions... (Elbowpunk)
Make sure the cat is really hot. Check to see if you're running too lean. And check your timing.
Old Jan 9, 2007 | 11:38 AM
bidnessb's Avatar
Here is some good advice from g2ic.
http://g2ic.com/forums/showthr...+test
I would try the cheap stuff (recommended by xdeep on g2ic) first.
I changed my spark plugs (gapped correctly), oil/filter and air filter.
Then add three bottles of "Heet" gas line antifreeze to a quarter tank of premium gas.
Make sure car is fully heated up before test.
I noticed a huge drop in all levels and passed easily.
Old Jan 9, 2007 | 12:00 PM
DC2 Mang's Avatar
Default Re: 90 integra cant pass "NOX" Emissions... (bidnessb)
are you running high compression pistons or something?
NOx only rises when the heat in the combustion chamber is too high
try changing your plugs and running higher octane gas to lower the combustion chamber temp's
Old Jan 14, 2007 | 08:06 PM
92_ integ's Avatar
dose your integra have a EGR? some of those years have it.
if it dose make sure it works
new oxygen sensor!
Old Jan 14, 2007 | 09:19 PM
1DA2NV's Avatar
i had the same problem with my G2, NOX was way to high, i found that my timing was off a bit and found that when it was brought back to sepc all was ok
Old Sep 12, 2007 | 08:32 PM
jin4g63's Avatar
same problem
dem0nk1d
Jul 7, 2006 11:11 AM
idewson
Jan 30, 2006 04:45 AM
serious
Aug 5, 2004 09:25 AM
matt j
20
Jun 10, 2003 09:39 AM
raene
Jan 9, 2003 02:31 PM
