DA integra 4-door question PLEASE HELP!!!!!!
Old Jan 9, 2007 | 01:09 AM
burnt_rice's Avatar
Default DA integra 4-door question PLEASE HELP!!!!!!
i recently replaced my coolant lines and my thermostat because my car would over heat but now my car over heats less often and i noticed that when i'm driving at night that my lights get dim as the temp gauge gets closer to the H (hot) and when he temp goes to normal my lights get brighter to back to normal and the temp somtimes goes up/down during idle and even during acceleration..i'm totally lost on what
s goin on with my car here guys any help you can assist me with would be greatly appriciated thanks in advance......
Old Jan 9, 2007 | 06:26 AM
Wraith_G2IC's Avatar
Default Re: DA integra 4-door question PLEASE HELP!!!!!! (burnt_rice)
The dimming lights sounds a little weird, but I would have to say it is 1 of 3 things.
1) possible bad temp sensor - not too likely since you said it does over-heat.
2) possible air in the system - if you don't bleed out all of the air then the air pockets will cause problems.
3) possible water pump failing - if it is not moving enough coolant then the engine will over heat. If you do replace this, don't over-look the timing belt as you will be right there already.
Old Jan 9, 2007 | 08:33 AM
burnt_rice's Avatar
yeah i'm going to bleed the air out today and see if that was the problem but that still doesn't explain my dimming light question when it over-heats
Old Jan 10, 2007 | 06:31 PM
burnt_rice's Avatar
i still need some help on this if anyone can help me out
Old Jan 11, 2007 | 05:30 AM
Default Re: (burnt_rice)
Have you tried looking around on http://www.g2ic.com ? Best site for the G2 Integra.
If you don't find the answer there, see if you can talk to RX3. He is fairly familiar with component interaction. He might be able to shed some light on the dimming.
Old Jan 11, 2007 | 07:44 AM
burnt_rice's Avatar
cool thanks i'll try this out
95Sedan
Jan 19, 2014 08:39 PM
Rikaro
14
Jul 23, 2010 09:19 PM
fdjizm
Mar 2, 2007 08:03 PM
b_serious
Nov 7, 2005 11:28 PM
