Removing MSD 6AL Ignition and BTM
Old Jan 8, 2007 | 07:11 PM
justint's Avatar
Default Removing MSD 6AL Ignition and BTM
I have an MSD 6AL ignition and blaster coil that I want to pull off and return to stock. Is it simply a matter of installing a new OEM cap, coil, and rotor and pulling off the MSD stuff to return the car to stock ignition?
Old Jan 8, 2007 | 07:55 PM
3000GTeg's Avatar
Default Re: Removing MSD 6AL Ignition and BTM (justint)
It is fairly simple to return one to stock, reverse the installation instructions
Old Jan 26, 2007 | 06:05 PM
Dynasty21's Avatar
From: Where We Squeeze 1st N Ask Questions Last, CA, USA
I want to do the samething... i bought a DA with the msd box and coil and want to take it off.. what do you do to put it back to stock? where does the stock coil go?
Old Jan 27, 2007 | 07:41 PM
ttracing03's Avatar
Default Re: (Dynasty21)
easy to install sock coil...it's under the cap. be prepared to spend about $80-90 on a new coil. you'll need to redo the +/- wires under the cap. not sure what the colors are but I can get then if you need them..good luck
Old Jan 28, 2007 | 09:07 PM
Dynasty21's Avatar
Default Re: (ttracing03)
please do so! I want to do this ASAP.
Thanks
Old Feb 20, 2007 | 11:47 PM
4drteg916's Avatar
i am just about to purchase a msd kit. the msd 6al with coil, cap, and 2step. why are u guys taking off the unit. is it not working properly or is it causing problems??? please reply. thanks
Old Feb 21, 2007 | 08:50 AM
4drteg916's Avatar
Old Feb 21, 2007 | 11:39 PM
Dynasty21's Avatar
I'm taking it off cuz I bought a DA with it and I want to sell it with the stock parts
Old Feb 23, 2007 | 12:23 AM
4drteg916's Avatar
was there any performance increase with the unit compared to the stock dizzy? was there better throttle response and better gas mileage? more hp?
Old Feb 24, 2007 | 06:21 PM
Dynasty21's Avatar
Default Re: (4drteg916)
very little difference if by itself... my car had headers, cold air, msd coil and msd 6al, stage 2 clutch and and lightened flywheel..
so with all those hell difference!
Old Feb 24, 2007 | 08:46 PM
4drteg916's Avatar
thanks ...
boostincoupe
Sep 4, 2006 06:56 PM
_oemek_
Aug 16, 2004 04:16 PM
marques4130
May 9, 2003 06:24 PM
