POST PICS OR BAN!!!!!!!!
Old Jan 8, 2007 | 04:21 PM
Ari's Avatar
Ari
* B A N N E D *
Default POST PICS OR BAN!!!!!!!!
Owner: Stumped!
Car: 1992 Acura Integra
Motor: Junkyard B18A1 // Motor had the following Stamps : " A " : 2357483 : " HM "
What I'm looking for is pictures of the Timing Belt set up for a stock LS motor [B18A1] .
Reason: Went to replace belt today , Bought belt from Auto Zone Part number # 95184.
Get back to the garage , Lined everything up to T.D.C. , Then proceded to put the belt on and in place and notice about 2 inches of slack!
So my 1st thought , It's the wrong belt! Take another trip to Auto Zone and verify it's the right one.
Guy behind the counter mentions non-vtec or someshit I think he was drunk So I just left in a pissed mood.
But When I originally bought the belt earlier today the guy was decent enough to print me out a basic picture of what my motor looks like [sideview] and how the belt is set-up.
So I'm looking at the picture after thinking the belt is too big , And this is what I see on the list:
Camshaft Sprokets: Current
Tensioner Pulley: Current
Tensioner: NONE
Crankshaft Sprocket: Current
Water Pump Pulley: Current
Idler Pulley: NONE
So I'm thinking maybe he gave me a wrong picture/diagram of another B series but as far as I thought , It was pretty much all the same set-up? .
To anyone who reads this please bump , The car is currently in a friend of a friends garage , And i'm getting charged rent space for it and tool usuage!
Please help out post pics or help full links that I can use for referance .
I have to be outta there by the end of tomarrow running or not , So any help is appreciated!
If there is any needed info I left out please ask , kinda tired here on 2 hours of sleep LNC FTW!!!
Edit: Car has no A/C or P/S!
- Ari
Modified by ari.. at 5:33 PM 1/8/2007
Old Jan 8, 2007 | 04:32 PM
Nataku's Avatar
Default Re: POST PICS OR BAN!!!!!!!! (ari..)
"POST PICS OR BAN!!!!!!!!"
Me: Doesn't respond to ********...
Old Jan 8, 2007 | 04:33 PM
Ari's Avatar
Ari
* B A N N E D *
Default Re: POST PICS OR BAN!!!!!!!! (Nataku)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nataku &raquo;</TD></TR><TR><TD CLASS="quote">"POST PICS OR BAN!!!!!!!!"
Me: Doesn't respond to ********...</TD></TR></TABLE>
Kill yourself , thx for the bump
Old Jan 8, 2007 | 04:40 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
do you have a pic of how you installed it, i mean if its on correctly and theres that much slack I dont see how it could be correct....shoulda went to Honda and got OEM anyways boyyyy
Old Jan 8, 2007 | 04:44 PM
Ari's Avatar
Ari
* B A N N E D *
Default Re: POST PICS OR BAN!!!!!!!! (It's*BOLO!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by It’s*BOLO!! &raquo;</TD></TR><TR><TD CLASS="quote">do you have a pic of how you installed it, i mean if its on correctly and theres that much slack I dont see how it could be correct....shoulda went to Honda and got OEM anyways boyyyy</TD></TR></TABLE>
It was installed right according to the way I took the old one off , and the picture I mentioned above , And the neareast dealer is a good 30 mins. away
Old Jan 8, 2007 | 04:48 PM
mrdeadman's Avatar
They let me pick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ari.. &raquo;</TD></TR><TR><TD CLASS="quote">
It was installed right according to the way I took the old one off , and the picture I mentioned above , And the neareast dealer is a good 30 mins. away </TD></TR></TABLE>
Ok so instead of going to the dealer and getting the right belt for sure... you went to autozone and don't know if you got the right belt. You could have been done by now if you had just gone to the dealer in the first place. 30 mins is not that far away, esp. if it is for your car.
Old Jan 8, 2007 | 04:49 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Cam--Cam
....O....O (tensioner, then waterpump)
...._
...\_/ (Crank)
That's all there should be,
is the Slack the amount there normally is until you Tighten the belt?
Once everything is lined up, tensioner still loose, belt on,
turn COUNTERclockwise, until tight,
Tighten tensioner pulley, and it should be fine.
Old Jan 8, 2007 | 04:55 PM
Ari's Avatar
Ari
* B A N N E D *
Default Re: POST PICS OR BAN!!!!!!!! (mrdeadman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">
Ok so instead of going to the dealer and getting the right belt for sure... you went to autozone and don't know if you got the right belt. You could have been done by now if you had just gone to the dealer in the first place. 30 mins is not that far away, esp. if it is for your car. </TD></TR></TABLE>
After thinking the belt was wrong I made the guy check for same belt part number 90-96 lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm &raquo;</TD></TR><TR><TD CLASS="quote">Cam--Cam
...._
...\_/ (Crank)
Tighten tensioner pulley, and it should be fine.</TD></TR></TABLE>
1st off thanks for the pic lol , 2nd the belt falls of right off , nothing is near tight mad slack son like the belt is wayy too big but compared both belts and they are the same size - I even counted the teeth on the belt nucca!!
Old Jan 8, 2007 | 05:30 PM
doood's Avatar
been there done that
did you tighten the tensioner?
Old Jan 8, 2007 | 05:34 PM
Ari's Avatar
Ari
* B A N N E D *
Default Re: POST PICS OR BAN!!!!!!!! (doood)
Yes, It just seems like I'm missing somthing thats why I asked to for pics , but from what it looks like everything that should be there is ....
Old Jan 8, 2007 | 05:41 PM
littlemissy's Avatar
Does it match up with your old belt??
Should have bought oem. I hate autozone crap belts. I've ran into so many problems with them. I've had to go back a few times till they gave me the correct belt.
Old Jan 8, 2007 | 05:44 PM
doood's Avatar
Default Re: POST PICS OR BAN!!!!!!!! (littlemissy)
it should be routed like this
Old Jan 8, 2007 | 05:47 PM
Racermech's Avatar
http://www.team-integra.net/se...=1044
Old Jan 8, 2007 | 06:01 PM
Ari's Avatar
Ari
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">it should be routed like this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">http://www.team-integra.net/se...=1044</TD></TR></TABLE>
Thank you guys!!!!
Ari
Jan 10, 2007 12:22 PM
Panoply
May 12, 2006 12:05 PM
AMG
Sep 3, 2004 10:09 AM
TodaSi
Jul 16, 2002 03:06 PM
