Sunroof plug(want to make my own)
Material
Fiberglass
Fiberglass Material
Electrical Grade Fiberglass (GP03)
Backing
Plain Back
Shape
Sheets, Bars, Strips, and Cubes
Sheets, Bars, Strips, and Cubes Type
Rectangular Sheet
Thickness
1/8"
Thickness Tolerance
±.010"
Length
36"
Length Tolerance
±.031"
Width
24"
Width Tolerance
±.031"
Opaque
Red
Operating Temperature Range
Up to +248° F
Performance Characteristic
High Tensile Strength and High Impact Strength and Flame Retardant
Tensile Strength
10,000 psi
Impact Strength
8.2 ft.-lbs/in
Tolerance
Standard
Hardness
Barcol 50
Specifications Met
Underwriters Laboratories (UL)
UL Rating
UL 94V0
Is this good enough to make a sunroof plug out of? Should I go thicker or thinner or is 1/8" thick good?
Looking for a material that can be sanded to the roof slope and can be painted.
If this material isnt good, I would gladly take suggestions.
For a 93 SI.
I tried the drag forum, but maybe it will do better in this forum.
Thanks.
Fiberglass
Fiberglass Material
Backing
Plain Back
Shape
Rectangular Sheet
Thickness
1/8"
Thickness Tolerance
±.010"
Length
36"
Length Tolerance
±.031"
Width
24"
Width Tolerance
±.031"
Opaque
Red
Up to +248° F
Tensile Strength
10,000 psi
Impact Strength
8.2 ft.-lbs/in
Tolerance
Standard
Hardness
Barcol 50
Specifications Met
UL Rating
UL 94V0
For a 93 SI.
Thanks.
RyanZ06
Jul 8, 2005 03:24 AM
