95' Civic - Need to find VSS line for aftermarket cruise
Old Jan 8, 2007 | 03:24 PM
kellyrmartin's Avatar
Default 95' Civic - Need to find VSS line for aftermarket cruise
Hi All. Would anyone know where I can find the Tach and VSS connections on a 95 civic LX? I am installing an aftermarket cruise and these are the only two connections that I am not absolutely sure of.... Thanks
Old Jan 8, 2007 | 03:49 PM
JSPECSIR's Avatar
Default Re: 95' Civic - Need to find VSS line for aftermarket cruise (kellyrmartin)
vss is in the speed sensor plug on top of the transmission. tach is in the tach test connector taped to the plugs on top of the drivers strut tower. it is a blue wire and can also be found in a 2 pin plug at the distributor. i cant remeber the color of the vss wire but i always catch it at the sensor. keep in mind you dont need to hook up tach unless its a manual transmission.
Old Jan 8, 2007 | 07:03 PM
Default Re: 95' Civic - Need to find VSS line for aftermarket cruise (JSPECSIR)
Hmmmm. sounds like I am hooked up to the right ones. I havent road tested the cruise unit yet but i did notice that it if I engaged it while idleing it would rev the motor for a second and then allow it to idel back down. The brake cuts it out properly though. Any idea why that would happen?
Old Jan 14, 2007 | 03:02 AM
JSPECSIR's Avatar
they shouldnt do anything below 25-30 mph.
compint
Nov 29, 2014 09:29 PM
civic08
Feb 28, 2008 09:22 PM
themorphious
Aug 22, 2005 01:29 PM
nonvtec
Apr 5, 2005 11:13 AM
95lsvteg
Apr 1, 2004 06:05 PM
