When resurfacing head or block, how much do you tell the machine shop to take off ?
Old Jan 8, 2007 | 01:03 PM
SoOHiGH's Avatar
Default When resurfacing head or block, how much do you tell the machine shop to take off ?
im about to resurface my head and block and wanted to know how much should be taken off. i dont want the machine shop to take off too much.
.006 ?
Old Jan 8, 2007 | 01:42 PM
Tippyman's Avatar
Default Re: When resurfacing head or block, how much do you tell the machine shop to take off ? (SoOHiGH)
Tell them to do just enough to make it flat. You don't want ur comp. to get raised too much if your FI.
Old Jan 8, 2007 | 02:07 PM
y7turbo's Avatar
Default Re: When resurfacing head or block, how much do you tell the machine shop to take off ? (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Tell them to do just enough to make it flat.</TD></TR></TABLE>
x2 thats all i ever tell them.
Old Jan 8, 2007 | 05:24 PM
90dxhmt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Tell them to do just enough to make it flat. You don't want ur comp. to get raised too much if your FI.</TD></TR></TABLE>
Old Jan 8, 2007 | 06:01 PM
Muckman's Avatar
Moderator in Chief
Its usually between .003 and .006".
This is a good thread to ask- how many times can I saftely have my head and/or block milled?
Ive had my block resurfaced 3 times and my head once, so say .004 each, thats .012" ! thats kind of alot, enough to raise my compression 0.3
Old Jan 8, 2007 | 06:18 PM
HamiltonRex's Avatar
Default Re: When resurfacing head or block, how much do you tell the machine shop to take off ? (Muckman)
When mine was done they went 0.006 it was warped, they said that was enough to cause an leak.
Just enough to make it flat, if its not flat its no good, and if they have to take off too much to make it flat, its scrap.
Old Jan 8, 2007 | 11:46 PM
SoOHiGH's Avatar
Default Re: When resurfacing head or block, how much do you tell the machine shop to take off ? (HamiltonRex
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Its usually between .003 and .006".</TD></TR></TABLE>
thats the answer i was looking for, I dont want my compression any higher then it is. thnx a lot.
Old Jan 9, 2007 | 04:02 AM
Topdawgg's Avatar
as much as it needs... i had one need .07, and another need .10... it all depends...
Old Jan 9, 2007 | 09:51 AM
SoOHiGH's Avatar
Default Re: (Topdawgg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">as much as it needs... i had one need .07, and another need .10... it all depends...</TD></TR></TABLE>
.10 ?
will it also depends on how high you want your compression. My head is fine, its not warped or anything.
Old Jan 9, 2007 | 10:09 AM
Topdawgg's Avatar
10 thou...
whatever that is...
that was taken off the last Dseries we put together
h22_crx
Nov 20, 2006 08:50 AM
walkerklondyke2000
Jan 12, 2006 10:11 PM
Black R
Nov 29, 2004 09:56 PM
cracker099
Mar 16, 2004 01:48 AM
sshaikh01
Sep 10, 2003 02:19 PM
