Repairing Blown Headgasket on d16a6
Old May 14, 2002 | 02:17 PM
jaje's Avatar
Default Repairing Blown Headgasket on d16a6
i bought an old d16a6 engine for really cheap...it has a blown headgasket...it's going into my 88 crx hf
i've never done a headgasket repair before but i have my helm's and a good working knowledge of engines
what do i need to buy to fix it and how much would the parts (gaskets) cost?
the engine is on an engine stand...what else should i do to it before installing it?...i.e. replace water pump, get flywheel remachined/lightened, get a lighter crank pulley?
tia
Old May 14, 2002 | 03:08 PM
fixhondas's Avatar
Default Re: Repairing Blown Headgasket on d16a6 (jaje)
You must get the metal updated headgasket and headbolts from Honda. If you reuse your old headbolts you will have a leaking new headgasket. Engines are easier to work on outside of the car- do what you can
Old May 14, 2002 | 03:23 PM
jaje's Avatar
Default Re: Repairing Blown Headgasket on d16a6 (fixhondas)
"metal updated headgasket"?...i'm not sure what that means...i'm going to the dealer tomorrow
Old May 14, 2002 | 03:33 PM
fixhondas's Avatar
The A6 came with a carbon grafoil headgasket originally- Honda then released a thick metal gasket to be used with the new headbolts. You can use a Y8 gasket for higher compression.
Old May 15, 2002 | 08:12 AM
jaje's Avatar
thanx for the info...i went to the dealer today and they do recommend the updated headgasket...the older one used to have leaks around the inner section of the intake manifold side
Old May 15, 2002 | 09:32 AM
88_SC_CRX_Si's Avatar
New User
92'-95' CIVIC Metal Composit is what I have heard it called... If you plan to do any work to the engine. Might as well spend the $$$$$ on ARP head studs. Belive me... they will quickly pay for themselves, the next time you have to pull the head. Replace the water pump for sure tho... Also, might as well re-hose it too. As far the flywheel goes, just depends on the condition of it.
Old May 15, 2002 | 06:47 PM
fixhondas's Avatar
Default Re: Repairing Blown Headgasket on d16a6 (88_SC_CRX_Si)
Yeah- I would go ARP- they will cost about the same as new headbolts from Honda and would be much stronger.
Old May 15, 2002 | 07:14 PM
jaje's Avatar
thanks guys...
kinda to clear it up...so arp is a brand of headbolts [studs] (like fram for oil filters)?...i should get the updated headgasket and the arp headstuds
Old May 16, 2002 | 11:43 AM
fixhondas's Avatar
Yes ARP headbolts and the gasket from Honda
Old May 16, 2002 | 12:27 PM
Steve91's Avatar
99% of the time when an aluminum engine blows a headgasket, the head needs to be resurfaced to make it level again. You never want to skimp on this step.
Old May 17, 2002 | 10:45 AM
fixhondas's Avatar
Default Re: Repairing Blown Headgasket on d16a6 (Steve91)
I also agree- I believe Honda made the metal "updated" head gasket thicker to accomodate milling the head some.
Mar 25, 2009 07:38 AM
kaz8teen
Jan 20, 2008 05:10 PM
.RJ
May 11, 2003 05:04 PM
cottagecreep
17
Apr 19, 2003 12:31 AM
Andrew 825SM
Feb 14, 2003 03:06 AM
