Widest wheels and tires possible on a 92-95 hatch????
what are the widest wheels and tires possible on a 92-95 hatch for a 16" wheel. i am curious about how wide i can go before i start rubbing up front.
thanks
thanks
Well that depends on how low you go and what spring rates you are running. I've seen CRXs and Civics run 13x8.5" wheels but that's extreme.
I run 16x7.5" with 43mm offset and it rubs on the rear upper control arm (the wheel does) and running 215/40x6" Kumho 712s with a 2" drop and 350f/400r spring rates.
My friend runs 17x8" Fittipaldi's on his '94 Si and the rear rubs on corners w/ his fat girlfriend in the passenger seat. You <U>should</U> be able to run 16x8's with the correct offset as said above.
B96v6
B96v6
running anything wider than a 7" wheel on a car as lightweight as a Civic is pointless. Why add the weight and friction unless you're strictly a drag racer? At some point, a larger contact patch begins to give diminishing returns because you're dispersing the weight of the vehicle over a wider area and therefore, there is less lateral grip.
werd...
I have 16*7 wheels. With 205/40-16 Kumho's..dropped anywhere from 1 to 6 inches depending on whether im drag racing, autocrossing, going to school, at a show, or bored and seeing if i can make my car not driveable.
If you are going with only a 15" wheel, go with 8. If a 16" wheel, go with a 7.5.
How low do you want the car? It all depends. For the power you are going to be making, I say go with a 8 width. 8 isn't a big deal, it just won't allow you to lower the **** out of the car.
[Modified by p0oty, 7:57 PM 5/15/2002]
pleej
Jan 7, 2010 03:43 AM
azian21485
Oct 3, 2004 02:29 AM
Flux
Jul 30, 2002 11:00 AM
